Results 1 to 2 of 2
Thread: An Africa problem! A well for water
Hybrid View
    DIY Junior Member Aussiemike's Avatar
    Oct 2012
    Kenya
    Default An Africa problem! A well for water
    Hi Guys,
    This is my first post.
    This is my first borehole.
    I had a borehole drilled 12 months ago.
    The guy who drilled it went walkabout and I never saw him again.
    I now have need of water for the property.
    All I know is that the hole with the casing is in place and capped.
    The depth of the well is 57.5 feet.
    The static water level is at 52 feet.
    Q1
    At what depth should I place the pump intake?
    Q2
    Do I need a filter and if so a link to "Dummies guide to installing a borehole filter."
    Thanks in advance for any assistance.
    Regards from Kenya
    Aussiemike
    Feb 2011
    NW Ontario, Canada
    5 feet of water is not a lot so you need to set it as low as possible. Research "cone of depression". What size casing? How many GPM can the well produce? Is this a rock bore or a mud well?
    A rock bore doesn't usually use any kind of screen. Whether or not a screen is required depends on the formation, whether the driller set a gravel pack, and what sort of GPM you will pull.
    My 65 foot 6 inch well casing stops one foot short of bedrock and has no screen. I have had problems of mud getting sucked up into the casing and had to flush it out and set some crushed stone. I also had to carefully develop the well to open up the formation for more GPM.
  1. Water softener problem, elevated copper in drinking water
    By SMS1944 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-30-2012, 12:45 PM
  2. problem ..scalding hot water from electric water heater
    By idreos in forum Water Heater Forum, Tanks
    Last Post: 03-11-2011, 07:17 AM
  3. Survey: Solar use in Africa
    By Sunny1 in forum Solar and Geothermal Water Heating Forum
    Last Post: 01-19-2010, 11:37 AM
  4. Low water volume problem from municipal water supply
    By bildy in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2009, 12:09 PM
  5. toilet problem / water supply line problem
    By lampe3d in forum Toilet Forum discussions
    Last Post: 01-16-2007, 02:59 PM
