Results 1 to 4 of 4
Thread: Can you reuse brass fitting when working with PEX
    DIY Junior Member Crassius's Avatar
    Oct 2012
    Virginia
    Default Can you reuse brass fitting when working with PEX
    Maybe this is obvious to some, but I want to be sure to avoid headaches in the future...
    I want to replace a valve in a PEX run, and plan on removing the existing valve by removing the PEX by cutting the crimp ring off one side of a brass elbow like the one pictured.
    I would then crimp new PEX pipe onto side of the elbow from which I cut the ring.
    Will this work, or am I inviting trouble by reusing the elbow?
    If you are careful you can reuse the fitting.
    Jun 2009
    Canada
    You have lots of room to cut the ring off without damaging the elbow, if the elbow still has all it's barbs on it you're good to go.
    Some PEX kits come with a crimp ring remover that does what you want to.
  1. 3" threaded brass wye fitting?
    By Lakee911 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-23-2012, 04:45 AM
  2. Clear solder from brass fitting
    By cmose in forum Plumbing Forum Discussion & Blog
    Last Post: 01-29-2012, 01:37 PM
  3. Reuse a soldered fitting?
    By newmex999 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-11-2010, 09:13 PM
  4. ABS Compression fitting to Brass tub drain
    By DIYMike in forum Shower & bathtub Forum & Blog
    Last Post: 03-06-2005, 05:48 AM
  5. Cannot unsweat brass/copper fitting
    Last Post: 02-17-2005, 04:50 AM
