Page 1 of 6 123456 LastLast
Results 1 to 15 of 82
Thread: TOTO Ultramax II, Gwyneth MS604114CEFG toilet reviews & pictures
    Default TOTO Ultramax II, Gwyneth MS604114CEFG toilet reviews & pictures
    TOTO Gwyneth MS604114CEFG toilet review
    Made in USA
    Video of performance
    Toto has a new model called the Gwyneth with the WaterSense Ecoflush.
    1.28 gallons, with the double cyclone rinse and Sanagloss in White, Beige/Biscuit and Bone. The Gray and Ebony/Black are without Sanagloss. It comes with the SS114 softclose seat and is the universal bowl height 16-1/8" before the seat is added. MaP testing has given it a 500 gram rating, which in many oppions is plenty for performance. Specs for Gwyneth
    Out of the box, the Gwyneth one-piece is a pop and drop installation.
    Pop the box, and drop it on some new wax.
    The bowl hase two rinse outlets near the top of the bowl, the water swings around the bowl when rinsing. Toto calls it their "Double Cyclone"
    White, Beige and Bone come with the super smooth ion barrier glazing that they call Sanagloss. I have a bowl downstairs with the same glazing that is 2.5 years old, and it's still very smooth, like the day it was installed.
    Inside the tank of the MS604 Gwyneth. It uses the Red Toto 3" flapper, replacements are found at most hardware stores. The fill valve prevents overfilling of the bowl.
    http://www.easycarts.net/ecarts/terr...l#MS604114CEFG
    Originally, TOTO had a one-piece and a two-piece Gwyneth
    These are now:
    MS604114CEFG, Ultramax II
    CST454CEFG, Drake II
    DIY Junior Member funkyd's Avatar
    Sep 2008
    Ontario
    Default Updated Review on Gwyneth
    Does anyone have any updated reviews or comments on the 1 piece Gwyneth (with or without Sanagloss). I am very close to purchasing 3 of them for my home reno and just want to make sure that they are as fantastic as they appear to be.
    Specs for Gwyneth
    DIY Member loke's Avatar
    Mar 2008
    Saskatchewan, Canada
    Have had our two Gwyneths since June (Sanagloss) and have had no clogs or problems. One does need to be sure to push the flush lever down completely (no need to hold there, though) as an incomplete push can result in an incomplete flush. Expect that's the same with all toilets.
    I really like the look, too.
    And if you have any concerns about the seat shape - one gets accustomed to it very quickly and I now prefer it to the flat seat on our 1 remaining waterhog toilet. Had some doubts prior to purchasing.
    Mar 2008
    Should have added that the bowl stays much cleaner than on our old regular style toilets (with the numerous holes under the rim). We'd get mucky buildup quite quickly on the old toilet and that just isn't happening now - maybe in part because these are NEW toilets. But swirling action of the double cyclone and having just the two openings under the rim is definitely good.
    DIY Junior Member GramGram's Avatar
    Jul 2008
    California
    Default Just Wondering...
    What are the advantages of this one over Toto EcoDrake besides Sani-gloss and Cyclone flush? I really like my EcoDrake and I'm trying to decide what to use in my other bathroom.
    Thanks,
    Sue
    SanaGlos is super smooth so things have more difficulty sticking and rinse off easier. It also has some antimicrobial properties. Personaly, I think it is a good choice. Some other companies offer similar finishes, but I haven't compared them. I know Duravit makes one they call Wondergloss (or something like that). Most toilets sold in Japan have similar finishes.
    Mar 2008
    Gram Gram -
    There probably aren't advantages for the Gwyneth over the Eco Drake if easier cleaning isn't important to you and you don't need a one piece. Maybe you aren't the one who has to do the cleaning!
    For me one important advantage of the Gwyneth was that it has about the shortest overall toilet height of the toilets with ADA height bowls - I had to contend with a banjo counter. But if height isn't a concern then there are more options.
    For my 3rd bathroom (basement) I would probably consider the Eco Drake, even with the possibility of more cleaning needed, just because I don't have the banjo counter there and the cost is much less.
    Default Gwyneth CST454CEFG
    Toto Also has the Gwyneth Two-Piece HET toilet with Double Cyclone rinse,
    Comfort height,
    Sanagloss
    With a good MaP rating.
    CST454CEFG
    http://www.easycarts.net/ecarts/terr...ts.html#cst454
    Specs for CST454CEFG
    I've been using a Gwyneth one-piece for a few months now.
    The water in the bowl is pretty similar to the Drake and Ultramax, except that there is a bit less volume in the bowl.
    The flush is pretty quick and rinses fairly well.
    The comfort height is nice.
    Specs for Gwyneth
    DIY Senior Member rsmith99's Avatar
    Feb 2008
    Oklahoma
    Default Gwyneth - Two Piece
    I installed a two piece Gwyneth a week ago and it is working fine.
    It was installed into a narrow space so I opted for the two piece to make it easier to set in place. (Bad Back!)
    The first Gwyneth I purchased was not flat on the bottom and caused it to rock. I took it back and got a new one. This one was perfect. The install went well. The first flush caused a gush of water to shoot out of the bowl and hit the wall. That made me worry. But after that initial flush, it has worked fine. The flush is very fast and the tank fill time is probably about 30 seconds. Much faster than the old toilet.
    The only problem I had was tightening the tank bolts. There are three tabs on the back of the bowl that are supposed to touch the tank when everything has been installed. I tightened the two tank bolts as far as I felt comfortable but there was still about a 1/16" gap on the left front tab. I am afraid to tighten it any further for fear of braking the tank. This is exactly why I would opt for a one piece toilet if I had room to maneuver around to install it.
    I am very glad I purchased a Toto toilet. Much more expensive than the standard toilets but it shows in the quality of the toilet.
    I don't even look at the tabs. I tighten until it feels right.
    DIY Junior Member ayeh's Avatar
    Feb 2009
    La Crescenta, CA (Glendale area)
    Default Gwyneth two-piece
    Hi Terry.
    I ran across your site today and have been studying it. I'm interested in the Gwyneth two-piece. You don't have any reviews yet, but I'm interested in it because I'm in the LA area. Do you think the Gwyneth might flush as well or better as my standard Kohler 1.6 from Home Depot a few years ago?
    Also, is there a reason that you cannot ship the CST454CEFG to LA?
    Thanks,
    Arthur
    Arthur,
    I sell the Toto in Clarmont CA, just a little East of Los Angeles.
    No shipping if you will call there.
    We also deliver in the area there for $39.99
    I've been using the one-piece version for a while, and the two-piece is supposed to work even a little better.
    http://www.easycarts.net/ecarts/terr...e_Toilets.html
    Terry Love
    Specs for Gwyneth
    DIY Junior Member Hans's Avatar
    Apr 2009
    Oakland California
    Default new two piece gwyneth
    I just had the two piece Gwyneth sanigloss ADA height (model CST 45CEF) installed, replacing a lovely water hog 1926 American Standard Devoro (not baby Devoro) with a hairline crack in the base.
    The flush on the Gwineth is awesome, and it handles the large masses as advertised. I selected this after much lurking on the website.
    The slow close lid is fun too.
    We had to re-pipe the fill line because the old toilet fill line came in at the top of the tank, not the bottom as in modern toilets.
    We are now noticing a sewer like odor or a urine odor when the bathroom door is closed (no interior fan yet).
    We suspect either a crack in the cast iron drain pipe or a clogged vent pipe or similar ,based on an article in the Ask the Builder
    Sewer Gas Smell
    By Tim Carter
    ©1993-2009 Tim Carter.
    I wanted a second opinion before I called the plumber in for a smoke test.
    Thank you so much for all your help.
    Joey
    DIY Member micp879's Avatar
    Jul 2007
    Martinez, CA
    Maybe try a new wax ring? It is possible that when you installed the toilet, the seal provided by the compressed wax ring was broken, allowing sewer gases to seap back into the bathroom from the sewer drain pipe. Have you noticed any water leaking around the base of the toilet?
    Default Toto Gwyneth not recommended?
    Terry,
    Am curious why the Gwyneth did not make your list of recommendations for toilets "that work in today's world". We just bought one (not installed yet) and now have second thoughts about it as it's not on your list at terrylove.com/crtoilet.htm.
    Which would you say is your favorite Toto 1.28 gpf (considering performance, price, and ease of parts replacement for a DIYer), the EcoUltramax?
    Sue
    P.S. Thanks for the great website and forum.
    The Gwyneth works fine. I need to update the list.
    MS604114CEFG in Beige
  1. Toto Ultramax II / gwyneth vs Ultramax
    By Raven4065 in forum Toilet Forum discussions
    Last Post: 11-05-2011, 06:38 AM
  2. Replies: 5
    Last Post: 09-09-2011, 04:04 AM
  3. Replies: 0
    Last Post: 08-04-2011, 05:50 PM
  4. Crane Drexel Toilet, pictures and reviews. A real water waster
    By Terry in forum Toilet Forum discussions
    Last Post: 03-03-2011, 06:42 PM
  5. Toto Gwyneth/Drake II/UltraMax???
    By organic_smallhome in forum Toilet Forum discussions
    Last Post: 08-17-2009, 03:44 PM
