Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Odd trap / drain depth question.
  1. #31
    Just so you know, I turned down a job this Summer where I would have had to crawl under a patio slab to work on the connection of the house sewer to the septic tank. The ground had settled and the connection had broken and was leaking water and sewage there. I let someone else crawl in there on their belly and did the top out.
  2. #32
    I cannot understand why a septic tank would have to be moved 100' if the existing one is under the house.
  3. #33
    Nov 2010
    Maine
    Nah, I'd still be grumpy. I was born grumpy
  4. #34
    DIY Junior Member RPN's Avatar
    Oct 2012
    MO
    If it has to be 25' from the house, there is no place to move it and still have room for the field.
    Exit the back door, take two strides, and you are standing on the tank. Take six more strides and you will fall straight down about 10'. It isn't straight down after that, but it is very steep.
    Standing at the back door, to the right of the tank is a postage stamp sized yard that I believe is the lateral field. To the left is hillside. (The house is set into the hill on two sides.)
    If you go up the slope far enough, we have a good sized pasture on the ridge top. We also have a couple of pastures in the opposite direction, but the pipe would have to cross a deep ravine.
    It is a beautiful place. Lots of deer, turkeys, foxes, raccoons, and way too many coyotes.
  1. Tub/Shower Drain Trap question
    By bigjon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-03-2012, 12:54 PM
  2. New Shower P Trap/Drain Question
    By belmontj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2010, 07:18 AM
  3. Shower drain P-Trap question
    By xianman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2009, 10:11 PM
  4. Shower Drain P-trap Depth?
    By Fightintxag in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2006, 04:58 AM
  5. Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
    By paule123 in forum Shower & bathtub Forum & Blog
    Last Post: 06-12-2005, 10:15 AM
