Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Trouble removing bathroom fixture...
    DIY Junior Member pdrmant's Avatar
    Oct 2012
    Dalworthington Gardens, TX
    Default Trouble removing bathroom fixture...
    I can't seem to find a tool or method that works for untwisting this strange nut.
    It's the one at the right of the pic. One for each handle. Is there some type of tool built for this?
    Thanks.
    You do NOT take this type of faucet out/ or apart from the underside. Remove the handle and trim, and there will be a nut holding it in. Take that off and the valve drops DOWN. A photo of the top would help us explain
    Oct 2012
    Aha... Here you are...
    Certified Plumber Plumber1979's Avatar
    Jul 2012
    Ontario
    use a basin wrench from underneath
    Oct 2012
    Quote Originally Posted by Plumber1979 View Post
    Tried this, but my basin wrench wouldn't get wide enough to grip the "nodes".
    I'm having a little success removing them from the top, as jimbo advised, but the whole section spins.
    As you can see, the faucets are corroded and quite old. I'm having a really hard time getting any twist or progress.
    I've been using vice grips on the geared protrusion shown to hold the unit in place while I use a crescent wrench, hair dryer, wd40 (all I've got at home), and some hammering. Painfully slow.
    Any suggestions for the bolt?
    Thanks.
    Regardless of whether you can loosen the nut on the bottom or not, the top one MUST be removed to take the faucet off the sink.
    DIY Junior Member mfellows's Avatar
    Mar 2011
    Rochester, NY
    Have you tried vinegar? If you're lucky, it will dissolve most of that corrosion.
    Oct 2012
    Quote Originally Posted by mfellows View Post
    OK, I'll try the vinegar today and see. Anyone give thumbs up on something like Liquid Wrench or some similar product?
    It looks like it is well beyond the "Liquid Wrench" phase. More like a Dremel Tool or hacksaw.
    Mar 2011
    Long Island, NY
    By the way, that nut is an electrical lock nut, which should be regular pipe thread. A pair of pliers should be able to grab it, but its difficult to figure out from here if there is enough room to fit in that area. You will have to be careful not to damage the basin, but you MAY be able to jam something like a large screwdriver in there to keep the nut from turning and try turning the valve body again, but as Jimb said, it may not be removable from the top up, as the valve body casting and it port may not fit through the hole. A Fein oscillating saw or cheap knockoff will be able to cut that inlet port off and allow it to fit through the hole Safety Googles are a must here.
    Good luck
    Nov 2010
    Maine
    Sawzall......
    Oct 2012
    Alright. Gonna try the screwdriver in the fitting method and see if she budges. Got a Dremel, too just in case. Thanks for the responses.
    That is NOT an electrical locknut, nor is it a "pipe thread". It is a "proprietary" locknut designed by the faucet manufacturer for THEIR faucet.
    Oct 2012
    If I were to go at this thing with a dremel, would I first remove (smash) the fitting that's so corroded to get to where I'm beneath the strangely shaped nut at the top. Then cut beneath the nut?
    You will have to remove the top fitting and let the stems drop down. You may be able to use a drill bit to "cut" through the nut. Just a series of holes until you have a cut that can be pried off.
    You may want to score it with a new hack saw blade a few times.
  1. Bathroom Fixture Hunt
    By Paul Browser in forum Shower & bathtub Forum & Blog
    Last Post: 01-06-2012, 07:03 AM
  2. Trouble removing excess silicone from sink
    By mntentman in forum Plumbing Forum Discussion & Blog
    Last Post: 12-15-2011, 02:21 PM
  3. trouble removing metal rimmed kitchen sink
    By Noahsoak in forum Plumbing Forum Discussion & Blog
    Last Post: 02-01-2010, 07:17 AM
  4. bathroom light fixture
    By rburt5 in forum Shower & bathtub Forum & Blog
    Last Post: 03-21-2009, 06:53 AM
  5. trouble removing old faucet - no room for basin wrench
    By grundy in forum Plumbing Forum Discussion & Blog
    Last Post: 07-28-2008, 06:09 AM
