Results 1 to 5 of 5
Thread: replacing shower body--what does "supply building with main shutoff valve" mean?
    DIY Junior Member dayexday's Avatar
    Jul 2012
    new york
    Default replacing shower body--what does "supply building with main shutoff valve" mean?
    This might be a dumb question. So as written above I'm replacing my shower body and the building sent me an email that when i replace the shower body I need to "supply the building with a main shutoff valves for your bathroom". What does this mean? I thought the valve goes inside the wall. I don't know what I'm supposed to supply them with. I asked the super to clarify but he doesn't speak english that well.
    The building does not like to have to turn of the water to everyone just so you can work on your plumbing.....not your fault because it was built that way. They are asking you at the time of your remodel work to install an accessible valve(s) to turn off the water to your bathroom. From a practical standpoint, that may not be possible, but for sure you should purchase a shower valve which has hot and cold stops built in. That allows it to be serviced without turning off the building. Your sink and toilet already have individual valves, presumably.
    DIY Member u.s.coins's Avatar
    Mar 2012
    Pennsylvania
    Quote Originally Posted by dayexday View Post
    ...i think they are worried that you're going to shut off everybody's water to the building. if you have shut offs for this fixture, of course no problem. that's how i read it anyway. hth
    Jul 2012
    new york
    i bought a shower valve with stops so that next time I can turn off water without building doing it. Is that what they're referring to? So the building doesn't "keep" anything? It sounded like they wanted me to give them something physical.
    They are asking for shut off valves for the hot and cold water TO your unit, so ANY work in it can be done without turning off the entire building. Your sinks and toilet should have individual shutoffs, BUT when THEY have to be replaced, and it happens frequently, they do NOT want to shuf off the entire building again. Depending on HOW the piping is arranged, a single pair of hot and cold valves may NOT satisfy their request.
  1. 1/2" PEX supply lines to Moen Shower valve
    By spooner in forum Shower & bathtub Forum & Blog
    Last Post: 12-11-2012, 04:46 PM
  2. Leaking Main Water Valve, can I just replace "innards"?
    By Minjin in forum Plumbing Forum Discussion & Blog
    Last Post: 09-24-2011, 01:16 PM
  3. Plumbing 101 - Reduce main supply to 1/2"
    By millerama in forum UPC Plumbing Code Questions
    Last Post: 03-22-2011, 05:49 AM
  4. 60" x 42" bathtubs with large base? (Replacing a tub-shower)
    By areacode514 in forum Shower & bathtub Forum & Blog
    Last Post: 08-17-2008, 08:46 PM
  5. Does anyone make an "in-line" tub-only valve body anymore?
    By MarkW in forum Shower & bathtub Forum & Blog
    Last Post: 07-22-2005, 12:42 PM
