Results 1 to 8 of 8
Thread: Am I going to poison my dogs?
    DIY Junior Member Jonathan Kozolchyk's Avatar
    Oct 2012
    Seattle
    Default Am I going to poison my dogs?
    Hi Folks,
    I made a simple water fountain for my dogs using a small fountain pump and "utility grade" copper tubing (3/8" OD) that I bought from Lowes. Is Utility Grade copper tubing safe for potable water? I didn't solder anything, just bent the pipe to get it out of the way and put a fitting on it to keep the sharp ends out of puppy reach.
    Here's a picture of the fountain (don't laugh at the bends! it gets the job done!):
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    poison? no. electrocute or kill them if the pump should fail? possibly. i would have the plump plugged into a GFCI outlet to be safe, if not just abandon the idea. Why is it needed?
    Oct 2012
    Seattle
    Thanks Chad! I have the pump plugged into a GFCI outlet. I don't know why, but the dogs like moving water. There are many similar fountains on the market, but they're all a pain to clean. My home made one is a lot easier to maintain.
    Copper is copper, the difference in grades refers to the wall thickness of the tubing, NOT the material it is made of.
    Nov 2010
    Maine
    My dog drinks out of the toilet whether the water is moving or not
    Sep 2009
    Seattle. WA
    quote; "refrigeration" grade where the tubing is
    cleaned, filled with moisture-free gas, and plugged, so as to avoid contamination of the refrigerant used in A/C&Refrig. machinery.
    It is also to prevent oxidation inside the tubing which could damage the components.
    quote; My dog drinks out of the toilet
    ANd he doesn't complain about you sitting on his water fountain?
    Nov 2010
    Maine
    Nah, he's old and senile
  1. Late September Dogs, the interview with Jamie Love
    Last Post: 06-14-2011, 09:58 AM
  2. Activists save Chinese dogs from cooking pot
    By Cookie in forum Health and Wellness Forum
    Last Post: 04-18-2011, 09:14 PM
  3. Late September Dogs at the Showbox August 15th 2009
    Last Post: 08-11-2009, 11:29 AM
  4. Handicap Ramps for Dogs
    By Dunbar Plumbing in forum Remodel Forum & Blog
    Last Post: 06-22-2009, 05:19 AM
