Results 1 to 3 of 3
Thread: Clay drain pipe
Hybrid View
    DIY Member Geo422's Avatar
    Feb 2012
    Cin oh
    Default Clay drain pipe
    Hi I have an four inch drain pipe which is broken. What do I use to connected an four inch PVC pipe to the clay pipe ? Thanks George
    DIY Junior Member jb 10's Avatar
    Apr 2014
    WI
    I'll reply with the same question.
    Here's one for underground, pvc to clay:
    Here's a shielded coupling for above ground, but I can't tell if it can also be used with clay:
    The P3000 series shielded coupling is EPDM for cast iron. Can it be used for clay?
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    A number of companies make the all rubber couplings for clay to plastic. Cut out the bad clay then whack off a chunk of plastic a hair less than the length of the gap. The couplings will slide over the plastic so you can set it in place and slide the couplings into position.
  1. How do you cut clay pipe????
    By Cybermonkey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2011, 03:40 PM
  2. How to attach to this clay pipe?
    By pghsebring in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-06-2011, 11:18 AM
  3. Clay Pipe tie in
    By burked1234 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2011, 02:08 PM
  4. Use Clay pipe or cast iron pipe for overhead sewer (50-60ft underground in yard)??
    By bnbhoha in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2011, 06:17 AM
  5. Ways to cut clay pipe?
    By Blade_Jones in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2006, 04:58 AM
