Results 1 to 5 of 5
Thread: Sewer Gas smell and bubbling toilet?
    DIY Junior Member ChrisRice's Avatar
    Sep 2010
    Indiana
    Default Sewer Gas smell and bubbling toilet?
    You all have been helpful in the past, so ill try again
    This just started happening recently...
    I have a laundry room /bathroom in my basement.
    Recently (as in the last three Sundays..laundry day) when the washer drains the first time there's a sewer gas odor in the basement. The odor goes away relatively quickly and does not return through 3-4 more loads of laundry. The toilet has also started bubbling as the washer drains and if you flush the toilet it is VERY slow to drain. I think its a bubble vs a gurgle, I'm not sure how to tell the difference.
    The sink and tub in that bathroom seem to drain just fine, though I haven't run an excess of water down them while this is occurring (just turned the water on for a minute or so).
    The toilet remains slow for 12ish hours, meaning I've gone back down a few hours after laundry and it's still slow, but the next morning it's always fine.
    I haven't altered anything and like I said it just started happening recently.
    Venting? A clog somewhere? Thoughts?
    Thanks in advance!
    Nov 2010
    Maine
    If you are on a septic tank I suspect you need to get the tank pumped and have them check the inlet baffle and possibly the D box at the same time.
    Sep 2010
    Indiana
    No septic, guess that'd been helpful first
    Jan 2008
    I would speculate that you have a partial clog in your main building drain going out to the city sewer.
    Because the WM dumps lots of water quickly because it has a pump. Once the pipe gets full from the partical clog back to where the toilet is, the toilet can't dump its water and waste into the mostly full pipe. If it can't move fast enough, it won't empty. Higher stuff from above can partially fill the pipe.
  1. Sewer gas from septic tank bubbling through P traps
    By RickRick in forum Plumbing Forum Discussion & Blog
    Last Post: 01-26-2011, 07:37 PM
  2. Another toilet install resulting in sewer smell
    By BigRob_NH in forum Toilet Forum discussions
    Last Post: 01-25-2008, 01:47 PM
  3. Fix Sewer Smell Coming From Unused Toilet
    By andreaarden in forum Toilet Forum discussions
    Last Post: 07-17-2007, 05:34 PM
  4. Sewer smell confined to inside of toilet bowl
    By Jim165 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-14-2006, 05:48 PM
  5. drains bubbling and "sewer smell"
    By boomer in forum Plumbing Forum Discussion & Blog
    Last Post: 12-27-2004, 02:25 PM
