Results 1 to 5 of 5
Thread: Installing a "bottle trap" drain in an older house
    DIY Junior Member boy412's Avatar
    Sep 2012
    Washington, DC
    Default Installing a "bottle trap" drain in an older house
    So we are tearing apart a small powder room in a 1950's home...and have hit a bit of a snag with the existing plumbing. We want to install a bottle trap drain with the new sink, since the plumbing will be exposed and we think these drains look cool. Something like this:
    The problem is the drain stub coming out of the wall is 2" threaded iron. The drain we like (above) looks to have a 1 1/4" outlet. So I'm wondering what options I have? I'd hate to remove the existing stub, since it would require cutting into a healthy plaster wall. Any ideas?
    Thanks...
    For a trap like that, you need a 1-1/4" thread at the wall. The nut barely clears the wall, and then the escutcheon covers that.
    It's time to open the wall if you want exposed plumbing that looks nice. Anytime somebody asks me about exposed plumbing, it's time to think about redoing the pipes in the wall to make sure they look good on the outside.
    The bottle trap, since it has no swivel, has to be dead on centered with the lav drain.
    Nov 2010
    Maine
    Bottle traps can be a bear to get lined up and besides that, in most places they are illegal
    Sep 2012
    Washington, DC
    Illegal? Wow. I'll need to check code in my area. Thanks for the heads up guys!
    Plumber jimbo's Avatar
    Despite general assumptions.....bottle traps ARE approved by the UPC.....with the proviso that the internal weir( separator) be made of material which will not corrode away....meaning plastic. you will probably find a CSA or UPC mark on the trap. Without that marking of course it is NOT allowed to be used.
  1. Slope requirement on 3" horizontal drain - 1/8" or 1/4" per foot? Drain design?
    By Kubota_Kid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2012, 11:47 AM
  2. Is this a "P" or "S" Trap or which is the better alternative?
    By dw85745 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2012, 07:28 AM
  3. Installing 1/2" NTP Grundfos recircultion pump on 3/4" NPT Water Heater
    By CountryBumkin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2011, 06:15 AM
  4. "Sticky" Temperature Adjust on older Delta Monitor
    By sarah_pdx in forum Shower & bathtub Forum & Blog
    Last Post: 08-28-2009, 07:11 AM
  5. "S" trap to drain pipe fitment question
    By TSPORT in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2005, 05:30 AM
