Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Tight space trap arm question
  1. #16
    Jun 2009
    Canada
    Exactly, it would have been fewer fittings too.
  2. #17
    General Contractor hdb's Avatar
    Sep 2012
    Central Coast, California
    I agree. There's a header above that small bay to the right, and I can't penetrate through it for obvious reasons. What I can do... is exactly what you're saying -- moving the combo fitting into the right bay, and then venting up and eventually 45 the vent back in to the bay above the washer box. Thanks for the good points. I'll post a picture when I'm done.
    That wall isn't CMU, it's a product call rock lath. It was used, around here, during the 50's. It's a 1/2" gypsum board with holes in it, came in 16" widths. It was ran perpendicular, and then it was covered with 3/4" of concrete. Plaster was textured on top of that for the finished product. It's the in-between from lath and plaster to drywall.
  3. #18
    quote; I have failed literally hundreds just like that and so has every inspector in the region.
    From that statment, I have to assume you are a city plumbing inspector, and if so, HOW can you not know what a 3/4 "S" trap is? When I was an apprentice, we had a neighboring city's plumbing inspector working for us. I fired him because he did not know what he was doing. When you got a few beers into him and asked him about apprentices, he would bemoan the fact that "He has been a plumber for 25 years, and some apprentice fired him".
  4. #19
    Nov 2010
    Maine
    I don't inspect anything anymore but that particular configuration has come to be known as a 3/4 S, why I can't tell you. Technically it is not, and neither is it a true S trap but it is an illegal trap because you need 2x the pipe diameter between the weir and the inlet and there ain't anything near 2 times the diameter there.
  5. #20
    IT does not even approximate a 3/4 "S" trap, nor does it approximate an "S" trap. It is a "reach" to even consider it capable of siphoning under ANY condition.
  1. How to maneuver a deep tub into a tight space
    By strawberryblond in forum Shower & bathtub Forum & Blog
    Last Post: 04-23-2010, 10:03 AM
  2. Need help selecting toilet in tight space.
    By Standupgal in forum Plumbing Forum Discussion & Blog
    Last Post: 04-27-2009, 04:50 PM
  3. ADA-compliant Toilets For A Tight Space?
    By HighRiseGuy in forum Toilet Forum discussions
    Last Post: 01-29-2009, 01:02 PM
  4. Insulation in a tight space
    By nelsonba in forum Remodel Forum & Blog
    Last Post: 10-31-2007, 07:35 AM
  5. Replacing galvanized in a tight space
    By Zach in forum Remodel Forum & Blog
    Last Post: 09-18-2005, 06:10 AM
