Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Building a better tile shampoo shower niche - a how to guide
  1. #16
    DIY Junior Member Keithett's Avatar
    Dec 2012
    Tigard, Oregon
    John,
    I've been reading up on how you create a shower niche and if I understand this correctly, you create an oversize waterproof niche opening so you have the ability to adjust the tile as necessary to match the surrounding tile. I'm going to be tiling a new shower next year and also want my tiled niche to match up exactly with the surrounding tile and like this approach. What I wanted to know is the best way to fill in the approximately 1" (plus or minus) gap behind the tile. Instead of filling this gap with thin set, would it be better to grout in a shim between the niche and the tile? If water behind the tile is a concern, I could make this shim out of a non-porous material.
  2. #17
    Jun 2009
    Canada
    John that small shower room w/ the toilet in it, does water make it almost to the door or what?
  3. #18
    Jul 2009
    North Vancouver, BC
    post(s) deleted by John Whipple
  4. #19
    Jul 2009
    North Vancouver, BC
    Default A tiled niche for toilet paper. Adding a wow factor
  5. #20
    Jul 2009
    North Vancouver, BC
    Default Shower Niche as a light source - working with Chromatherapy lighting
  6. #21
    Jul 2009
    North Vancouver, BC
    Default Adding storage to a shower niche - how to design and build extra space into the nice.
  7. #22
    DIY Junior Member sriniwass's Avatar
    Oct 2013
    Huntersville, North Carolina
    John,
    What is the brand\model of LED lights you used to light the shelves in the niche? Thanks.
    -Sri
    -Sri
    My project on the John Bridge Forums: Gut and Remodel Master Bath with Curbless Shower
  8. #23
    Jul 2009
    North Vancouver, BC
  1. rotating into place retrofit 5 foot niche tub
    By tbb2 in forum Shower & bathtub Forum & Blog
    Last Post: 02-02-2012, 08:28 AM
  2. tile cutter guide fence isn't square.
    By AcidWater in forum Remodel Forum & Blog
    Last Post: 03-21-2009, 02:43 PM
  3. Building a shower ??
    By WV Hillbilly in forum Shower & bathtub Forum & Blog
    Last Post: 12-17-2008, 12:02 PM
  4. Building a shower pan
    By jrodela in forum Shower & bathtub Forum & Blog
    Last Post: 12-07-2008, 07:20 AM
  5. Information on Running a Frost Free Water Line from building to building
    By staysteady in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2008, 10:07 AM
