Results 1 to 8 of 8
Thread: Lights Flickering - bad splice in panel?
Hybrid View
    DIY Junior Member mhmmofro's Avatar
    Sep 2011
    staten island
    Default Lights Flickering - bad splice in panel?
    Backround:
    100 year old house with 90% new / newer wiring, New panel installed 18months ago, service and meter and weather head from ~60's.
    About a month ago i noticed some of my lights flickering. I shrugged it off until i saw it happening more consistently. The circuits i was seeing the flickering on were both old and new. I went outside and my meter base is looking a bit weathered and it is rusting at the bottom. I then popped the cover off my panel.
    As you can see the electrician used these splices. The red one seems to have failed or at least the outer insulation has failed. The circuits that are flickering are on this leg.
    My questions are:
    1) what kind of splice is this?
    2) why did it fail?
    3) At 18 months out should i expect a warrante repair?
    markName:  DSC00917.jpg
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    I would call it an insulated, compression, butt splice. It is a legitimate way to splice wires.
    What went wrong? I don't know. I can't tell from the photo. It does look like a bad splice and needs to be fixed and soon.
    Warranty? Unless you are upset with whomever did the work I would him first. If he is a stand-up guy and made a goof he will fix it. If the problem is caused by something not related to the work he did then their will be another charge. If you decide to call someone else then find an electrician with good references, get it fixed, write the cheque, and move on.
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    WHY in the world they have changed the panel and leave a '60's vintage service entrance????
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Hack job. You do not splice in a panel.
    Sep 2012
    Anaheim, Ca.
    Quote Originally Posted by Speedy Petey View Post
    Agreed. The best way would have been to rewire the whole house at once. I sense the entire house is full of skeletons such as this. Expensive, but a good piece of mind. When I see something like this that is visible, I get very concerned about the hidden you cannot see.
    Sep 2011
    staten island
    Thanks for the answers guys. I left it original to the panel to save money and because the sparkies who checked it out told me i would be fine for at least 10 years. In terms of the splice in the panel i was told it was fine I dunno. Clearly you can see why one would not want a splice in the line - crap like this happens.
    Sep 2011
    staten island
    The guy who did the work is supposed to come check it out on Monday. Could poor balancing of the phases cause this? I mean could having to many high current items on this phase cause the splice to fail even if it was installed correctly?
  1. Flickering lights on circuit with low voltage and line voltage bulbs
    By davidwie in forum Electrical Forum discussion & Blog
    Last Post: 04-18-2011, 07:34 AM
  2. New splice fitting
    By thezster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2009, 04:59 PM
  3. Connecting a 3/0 Splice
    By JoeyC in forum Electrical Forum discussion & Blog
    Last Post: 12-31-2008, 07:36 AM
  4. Flickering lights
    By jparrie in forum Electrical Forum discussion & Blog
    Last Post: 11-19-2008, 12:22 PM
  5. Splice sprinkler cable?
    By mntentman in forum Irrigation / Sprinkler Forum
    Last Post: 08-04-2008, 06:35 AM
