Results 1 to 4 of 4
Thread: Propane Gas line to Range
    DIY Junior Member jlw3141's Avatar
    Feb 2013
    Pennsylvania
    Default Propane Gas line to Range
    I know messing with gas is potentially dangerous but i'm quite confident i can do i safely and properly so i wanted to run my plan by you guys before i start things..
    Its a very simple project, hooking up a gas(lp) range in my shop, about 6-8' away from a 100lb tank located in an adjacent room. My plan is to run 5/8" type k copper tubing (which already have around from another project..) from the tank to the wall where the range is located. From the range to the 5/8" flare fitting i have a flexible yellow gas line with the correct fittings to make the connection. At the tank i will the connect the 5/8" flare with proper fittings to a POL fitting that will screw into the tank. I plan on testing all connections with soapy water..
    My questions are:
    1) Is the line sizing alright? ( i know its not too small, but is there anything wrong with too large? )
    2) Do i need another regulator at the tank before the line, in addition to the one that is installed in the range? If so, what rating?
    3) Do i want 'Full Flow' POL fitting at the tank or a 'restricted flow' one? I am assuming full..?
    Thanks a lot!
    JW
    You need a "first stage" regulator at the tank, and if you get the right one it will have the tank fitting attached to it. The one at the range is just to "stabilize" the flow. The tank regulator does NOT have "full flow/rstricted flow" ratings. Does your fire department know you have a 100# propane tank INSIDE a room, and does your insurance company also know about it?
    Unless that 'room' where the tank is has no walls (i.e., is exposed to the elements), you have a very dangerous situation. Propane, being heavier than air can pool at the floor level and you may never notice a leak until it is too late and the house blows up. There's a good reason why it's illegal and ill-advised to have one in a closed room.
    Feb 2013
    Pennsylvania
    Thanks for the reply's. The shop is in my barn, and the tank Is in a room that is open to the elements, 3 walls the fourth is open to the outside, there is plenty of air flow.
  1. Gas line - Converting from dryer to range
    By Spaceball1 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-17-2011, 07:45 AM
  2. Range Gas Line Remodel Box?
    By Glenf in forum Remodel Forum & Blog
    Last Post: 01-27-2009, 05:53 PM
  3. how do I purge gas line? I installed new gas range.
    By Handyman Miguel in forum Plumbing Forum Discussion & Blog
    Last Post: 09-12-2006, 08:20 PM
  4. running propane line for new range
    By cgcnstr in forum Plumbing Forum Discussion & Blog
    Last Post: 07-05-2006, 05:24 AM
  5. New Propane Line
    By inwolf in forum Plumbing Forum Discussion & Blog
    Last Post: 10-23-2005, 11:39 PM
