It kinda sounds like the capacitor. It should be cheap enough to replace, but if the fan itself is a cheapo, then maybe better to replace it. I'm not even sure if (3) speed ceiling fans all use caps or if they use multiple pole configs that the switch changes from one spped to another. I'd go with the cap if you can find one. Do you have an old analog type ohm meter (with a dial and needle)? If you do, the cap can be checked to see if it is completely open (or shorted out) I would think if it failed and caused the motor to reverse itself, it may have lost its capactance (opened). only my .02.
, but I am a pro crastinator
