Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Dim Glow in Incandescent Bulb When Touched
  1. #16
    You're all missing the point that the switch was ON when he replaced the bulb, neither the original, nor the new bulb worked, but when touching the bulb, it glowed slightly...the power was already there, but the connection was/is lousy...my opinion is that there's a bad connection, either a rusted socket, or corrosion on the contacts...this is an outside lamp where humidity and maybe rain will affect it.
  2. #17
    Jun 2007
    North Carolina
    You tell them boss man, I agree
  3. #18
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Uhmmm,. . errr,. . . I kinda said that.
    And, ummmm,. / well I mean uhhhh,. . shucks ya know, I don't want to make big deal or anything. Normally I would not call attention to myself. It's just that JW said I was the winner and I don't want to miss out on my prize.
  4. #19
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Quote Originally Posted by BobL43 View Post
    By the way, what is the wattage of this bulb?
    Interesting question. Why do you ask?
  5. #20
    The fixture is 8 years old and a porch lamp, outside. Brass finish and has seen some serious wear.
  6. #21
    To answer the questions:
    We don't know how he touched the bulb, was the glass damp, dirty, etc, --> I touched the bulb at the top while on a ladder. The glass on the bulb was brand new, clean and dry.
    are you SURE it is incandescent and NOT a Compact Flourescent bulb? --> Yes, absolutely incandescent, not CFL.
    what is the wattage of this bulb? --> 100 Watt
    Light switch was ON while changing. (Opps)
    I think jadnashua nailed it on the head given the environment the fixture sits in. I'd guess nearly 10-15 feet proximity to a tall sprinkler... we don't get a ton of rain here in Southern California. Sounds like a shot socket. I'm ready to replace the darn thing, especially since there are ones that aren't terribly expensive and look nice.
    Thank you so much for all of the GREAT responses. I've learned a ton from this post.
  7. #22
    And if that does not work try another. Rinse, lather, repeat. when to stop? could not resist. Sorry Cookie!
    Ha ha, lol. But, I have bought brand news bulbs that wouldn't work, sooooo... in light of that lol, can't hurt to try.
  8. #23
    In the Trades dwindle's Avatar
    Nov 2012
    North East Pennsylvania
    If he had enough current running through his body to light a filiment, he'd know it.
    ___
    I say it's just a dirty connection at the base of the outlet. Use a small piece of wood to scrape it clean, with the switch off. Blow any residual dust out of it.
  9. #24
    Mar 2011
    Houston, TX
    lol.
    Check the old bulb. If it is good it is most likely a loose connection.
    If it is bad then it is most likely a loose connection, or the new one is bad or the wrong type.
    A Compact Flourescent bulb may light to the touch of the glass but not a incandescant, unless applying pressure makes a better connection.
  10. #25
    quote; Current does not leak to earth so this is not it
    Maybe it doesn't "leak" but if you are between the "current source" and the earth, it WILL go through you.
  1. Question for Ba9s LED Bulb
    By nicho in forum Electrical Forum discussion & Blog
    Last Post: 09-24-2012, 07:01 AM
  2. 20 Year LED Bulb
    By DonL in forum Bob & Don's Electronics Forum
    Last Post: 07-15-2012, 07:26 PM
  3. Rheem 04EAUSR. Igniter doesn't glow.
    By Rickcusaf in forum HVAC Heating & Cooling
    Last Post: 01-06-2012, 02:10 PM
  4. Light Bulb
    By Maverick_54 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-15-2011, 11:13 AM
  5. Bulb for bathroom
    By Dexter in forum Remodel Forum & Blog
    Last Post: 09-21-2008, 11:29 AM
