Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Dim Glow in Incandescent Bulb When Touched
    Unhappy Dim Glow in Incandescent Bulb When Touched
    Hi There,
    I'm completely new here and have no experience in electrical work. I have a front porch light where the bulb burnt out. I went to replace it with the light switch turned on and nothing initially happened until I touched the bulb. It had a faint glow in the filament. What's going on? I'm scared that I did something very dangerous and certainly won't be touching it again. Thanks. -- Alexsis
    Feb 2011
    NW Ontario, Canada
    There is a small current leaking to earth through your body.
    Fabulous... Scary stuff. Thanks for letting me know. I appreciate the response.
    Plumber jimbo's Avatar
    I am guessing you have an open neutral on the bulb circuit
    What does that mean in newbie terms? Sorry, forgive me and I appreciate your patience.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Really. How is the current getting through the bulb, through him, through his footwear, and to the earth in enough quantity to make a filament glow?
    Feb 2009
    Colorado
    Quote Originally Posted by Alexsis Miller Veal View Post
    There is a method of wiring circuits that if there is a problem, can cause dimming of light bulbs. I don't think we need to go there yet.
    How old and what is the condition of the light fixture? What you are describing could be a poor connection between the light bulb and the socket.
    There might be a loose or corroded connection and when you screwed the bulb in, you applied a little force, moved things, enough to make the partial connection. If there is corrosion, it can act like a resistor - effectively like putting a bunch of light bulbs together in series (most stuff in a house is wired in parallel so that power doesn't have to go through one thing before it gets to another, which is series - think putting two batteries in a flashlight - they are in series - if one is bad, the bulb may still light, but it won't get as much voltage and be dim).
    A porch light will see lots more moisture and corrosion than a fixture installed in the house. There could be rust, too.
    Try another bulb.
    Quote Originally Posted by ActionDave View Post
    My thought was that in the absence of a neutral connection, capacitance thru his body MIGHT allow enough current. We don't know how he touched the bulb, was the glass damp, dirty, etc,
    Jun 2007
    North Carolina
    Current does not leak to earth so this is not it
    Jun 2007
    North Carolina
    If there was no neutral then no path and nothing would happen. If there was enough capacitance between the body and the bulb to cause it to glow then they are dead
    Jun 2007
    North Carolina
    We have a winner
    Mar 2011
    Long Island, NY
    Hi There,
    Alexis, I know you said it is an incandescant bulb, and that is has a filament, but are you SURE it is incandescent and NOT a Compact Flourescent bulb? I personally know several people who call CFL's incandescant. And the other answers of a Neutral connection being bad "might" make more sense if your bulb is a CFL. Maybe
    By the way, what is the wattage of this bulb?
    Mar 2011
    Long Island, NY
    Quote Originally Posted by Cookie View Post
    Try another bulb.
    And if that does not work try another. Rinse, lather, repeat. when to stop? could not resist. Sorry Cookie!
  1. Question for Ba9s LED Bulb
    By nicho in forum Electrical Forum discussion & Blog
    Last Post: 09-24-2012, 07:01 AM
  2. 20 Year LED Bulb
    By DonL in forum Bob & Don's Electronics Forum
    Last Post: 07-15-2012, 07:26 PM
  3. Rheem 04EAUSR. Igniter doesn't glow.
    By Rickcusaf in forum HVAC Heating & Cooling
    Last Post: 01-06-2012, 02:10 PM
  4. Light Bulb
    By Maverick_54 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-15-2011, 11:13 AM
  5. Bulb for bathroom
    By Dexter in forum Remodel Forum & Blog
    Last Post: 09-21-2008, 11:29 AM
