Results 1 to 5 of 5
Thread: Buying a used water softener - bad idea?
    DIY Junior Member JoshB-NC's Avatar
    Sep 2012
    North Carolina
    Default Buying a used water softener - bad idea?
    We need a water softener for the house we just bought (on well water). There are quite a few used systems in my area for sale as more and more houses are connecting up to the county water. Is it best to just buy a new system or is used ok? I found one with a fleck control (basic 5600 I think). Do the tanks go bad? How much is the resin? It looks to be a 48,000 system. I think I could buy it for $100.
    There are also quite a few Culligan systems. I assume to stay away from these even if they are work (parts would be expensive if it does break?)?
    great forum!
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    If you can hook it up and go than it's a great deal. If you have to rebuild the entire unit, your cost could get up to $400. Another $200 and you got a new unit. By checking the unit before buying would give you an idea of what, if anything, is wrong.
    Sep 2012
    North Carolina
    Do the tanks ever go bad or get contaminated? How do you know if the media is good or not? I agree.. I do not want to dump a bunch of money into it when I could just buy a new unit.
    Nov 2010
    Ocala, Florida
    A tank is bad if it leaks. Other than that, it won't go bad. If when turning the center knob (regen knob) it binds up, the valve needs to be rebuilt. If you can get a sample of the resin, squeeze it bewteen you thumb and finger. If it's bad, it will feel like mush.
    Sep 2012
    North Carolina
    Ok thanks for the info!
  1. Need Help Buying a Sediment and Water Softener System.
    By vpr80 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-24-2012, 07:02 AM
  2. Absolute Newbie wants to fix own Grohe 33 625 shower faucet - good idea? bad idea?
    By plumbernotme in forum Shower & bathtub Forum & Blog
    Last Post: 12-18-2011, 05:23 PM
  3. Is it a bad idea to drain softener into the ground?
    By Mastiff in forum Plumbing Forum Discussion & Blog
    Last Post: 10-11-2010, 10:21 AM
  4. Draining a water softener into a septic system...bad idea?
    By Mikebarone in forum Plumbing Forum Discussion & Blog
    Last Post: 10-30-2008, 05:33 PM
  5. Wife wants a Water Softener. Bad idea?
    By LawyerRon in forum Plumbing Forum Discussion & Blog
    Last Post: 06-04-2007, 07:17 AM
