Results 1 to 8 of 8
Thread: Shower noise
    DIY Junior Member nadia's Avatar
    Sep 2012
    Texas
    Default Shower noise
    I have a moen single shower faucet and it makes a noise when the water handle is in the middle the noise stops when the handle is all the way on hot or cold. Do you know what the problem is
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by nadia View Post
    I wish I could help you. Sometimes showers make strange noises. Is it a new install or and older one?
    JW
    Feb 2011
    NW Ontario, Canada
    You have not provided enough information to determine whether the "problem" is real or imagined. Is this a new installation or old? If old, has the noise level changed over time?
    Most modern shower valves have a pressure balance spool that monitors the pressure on both supplies and meters the output accordingly. This spool can produce a sound. The constriction of flow through the valve also produces a sound. When the control is set to full hot or full cold, the restriction on one side is less and the pressure balance spool seeing only one side has no role to play.
    In the ''middle" is when the flow is the greatest. Take the shower head off and run the water to see if that is where the noise is occurring.
    DIY Junior Member Natineah's Avatar
    Sep 2012
    I suggest that you call a plumber in your area because I can't really determine the problem of your shower.
    Sep 2012
    Texas
    [QUOTE=johnfrwhipple;356975]I wish I could help you. Sometimes showers make strange noises. Is it a new install or and older one?
    It is an older shower
    Sep 2012
    Texas
    It is an older shower.It is a townhouse built in 2007 and I just bought it and the sound is very loud.When the water is on it does not make a noise when the handle is all the way on hot or cold but when the handle is in the middle after a few minutes the sound starts. I have taken the shower head down but the noise still comes through the water pipe.
    Sep 2012
    Texas
    I took the shower head down and the noise was still coming through the pipe.
  1. shower drain noise
    By vmplumbing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-27-2007, 02:35 PM
  2. shower pan making popping noise after shower
    By mf915 in forum Shower & bathtub Forum & Blog
    Last Post: 04-13-2007, 02:06 PM
  3. Pipe noise from shower body?
    By tjlank in forum Shower & bathtub Forum & Blog
    Last Post: 11-01-2006, 09:19 AM
  4. Shower stall noise
    By DMS222 in forum Shower & bathtub Forum & Blog
    Last Post: 05-20-2006, 07:24 AM
  5. Jackhammering Noise in Bath/Shower
    By JRoyer in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2006, 05:15 PM
