Results 1 to 9 of 9
Thread: Water heater tank leaks, gonna have to replace SOON!
    DIY Junior Member Glowrdr's Avatar
    May 2008
    Minnesota
    Default Water heater tank leaks, gonna have to replace SOON!
    Apparently this is the year for plumbing. Just installed a water softner about a month ago. Well, low and behold - my water heater is leaking. Got a quote, but for $1200, I think I'll do this myself. I've got a couple other little "tasks" that I want to do as long as I've got the lines drained anyways (i.e. adding valves, and fixing another leak that's unrelated).
    Anywho... I'm down to these 3 options, but I'm looking for some opinions. I know the Rheem branded one has the magnesium rod, but not sure about the others. Someone here mind giving me your 2 cents? I'm gonna have to do this sometime this week as I have no drain in my basement, so time is of utmost importance in getting this ball rolling. Another month and I might have a pool in the basement.
    Richmond, ******* - $398 (I see this got blocked, its one over at Maynerds) - probably is my #1 choice unless the Rheem Fury is better
    http://tiny.cc/vfl7kw
    GE, Home Depot - $398
    http://www.homedepot.com/webapp/wcs/...ctId=100187010
    Rheem Fury, Online - $373
    http://www.wayfair.com/Rheem-Fury-40...FexFMgodKUwAZg
    I think the 40 gallon works, and the warranty doesn't really matter. It appears feature-wise, the 9 year happens to be the magic point for me, so these all should be apples to apples.
    Yakima WA
    I like Rheem heaters. Forget about length of warranty, you get the same heater for more money to get an extend warranty. If the heater fails anywhere near the end of the warranty period, it is worthless anyway. The only plus for buying for HD is if you have an immediate problem, you are dealing with a local store and not an on-line dealer. The OL dealer would probably make good on a replacement, but you'd have the hassle of sending the unit back and waiting for a new one. Not worth the $25 IMHO.
    Those 3 units are essentially the same unit with different labels. All made by Rheem, all probably the 6 year warranty version. If you buy on line, who delivers it and for how much????
    May 2008
    Minnesota
    I ended up pulling the plug on the top one I was looking at. Forgot that M'nerds takes competitors coupons, so I got 10% off of it. As for the online delivery, not sure how that would work. It was free shipping - but that kind of scares me in a way. And Gary - that was exactly what I was thinking. If I buy local, and something goes wrong - I drive 2 miles down the road and take care of the situation.
    I thought that I had a little bit of time, but I actually have someone willing to lend a hand putting this in, and he wants to do it tomorrow. Certainly couldn't turn down the offer.
    Yakima WA
    Amen on accepting the offer of help.
    Aug 2009
    Midwest
    Not sure if you bought one already or not: "pulling the plug" general means killing an option rather than selecting it, but it sounds like you went with it instead. In case you haven't already got the heater in hand you might want to quickly consider tank size.
    I'm assuming that you have a 40 gallon and are replacing with a 40 gallon? You didn't state what size you have. If the current size meets all your needs then that would be good. If it is a 50 gal at present, then a smaller tank is generally not a good choice. The difference in energy use from 40 to 50 gallon storage is typically small.
    If you have a large soaking tub in future plans or you might sell the home during the life of the water heater, then a 50 gallon might be a better choice. Another thing to check might be any local code guidelines about tanksize vs. home size/bedroom/bath/shower count.
    Good luck!
    May 2008
    Minnesota
    Thanks for the tip Runs - Yeah, I'm just replacing a 40 for another 40. Should be a little more efficiant, and I had a Rheem Fury from 1989 that finally gave way.
    It's actually just the wife and I, so a 40 works out well. (I think it's 2 people, 1 shower, 1 washing machine, 1 dish washer = 5-7/40 gallon). I'll probably get better results with slightly higher BTU, as well as reclaiming whatever room the sediment had taken over. I fully admit to never having performed any type of maintanance on this unit, and I guess it wouldn't suprise me to see the previous owners didn't either. Now that I've done a little research, I fully intend on flushing it yearly as well as inspecting the anode rod every few years. I've heard conflicting stories about water softeners (just installed one about a month ago). Makes sense that removing the sediment from the water would prolong a water heater, but I can also see the side that says the sodium in the water attacks the anode/tank more. Either way, I'm going to be a little more proactive at performing maintanance on this new unit.
    Thanks for everyone's help. I may not have grown up with the internet, but it sure is nice to have a place to goto now!
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    To get away from salt use potassium tablets in your softner
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    quote; I'm going to be a little more proactive at performing maintanance on this new unit.
    Normally, that lasts about 3 months.
  1. repipe hous and now hot water heater leaks
    By ab51464 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-16-2011, 06:49 AM
  2. New Water Heater, now T&P leaks
    By jdon88 in forum Water Heater Forum, Tanks
    Last Post: 08-26-2010, 05:06 AM
  3. Replace or Repair Tank Water Heater
    By odyinpdx in forum Water Heater Forum, Tanks
    Last Post: 09-30-2009, 12:03 PM
  4. To replace or not replace...hot water heater?
    By hhcibtpaun in forum Plumbing Forum Discussion & Blog
    Last Post: 07-03-2009, 10:14 AM
  5. Water heater leaks.
    By kingnus in forum Water Heater Forum, Tanks
    Last Post: 04-26-2009, 05:23 PM
