Results 1 to 14 of 14
Thread: how to unthread black iron fitting
Hybrid View
    Default how to unthread black iron fitting
    Hi, what is the typical method for unscrewing a black iron pipe from a fitting? the pipe is 1" threaded coming out of a 1.5"-1" reducer hung from the ceiling in my basement. Will just two pipe wrenches and some heat work or do I need a special tool?
    thanks
    Two pipe wrenches should be fine. If that's not enough, sometimes heating the female fitting helps.
    Yakima WA
    A couple of other things you might try if two pipe wrenches won't crack it loose are some PB Blaster on the fitting, and/or cheater handles on the wrenches. FWIW, PB Blaster is an excellent penetrating oil. Many folks try WD-40, but that is not a penetrating oil. It has its place, that this isn't one of them. I'd be careful with heat if the fitting is close to the ceiling.
    thanks!
    Is liquid wrench similar to PB? I've already got some lying around if so. The fitting is probably about6-8" below the open floor joist.
    Go ahead and try the Liquid Wrench. Just be very careful if you then try to heat it, as the oil will smoke and burn. Often, all you need is a bigger wrench.
    Yakima WA
    Yes, I think Liquid Wrench is a comparable product, PB Blaster may be a tad better, but I've never seen result of a test between the two.
  1. Black Iron Pipe
    By Soto in forum Boiler Forum
    Last Post: 05-13-2010, 08:28 AM
  2. How do I unthread pipe from a fitting?
    By awardmont in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2010, 05:57 AM
  3. cast iron fitting installed in cast iron soil pipe
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2009, 06:20 AM
  4. Black iron
    By Riosman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2007, 10:56 AM
  5. Black Iron & Copper Together
    By emerrill1@comcast.net in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2005, 10:41 AM
