Results 1 to 8 of 8
Thread: Sump Pump Question
    DIY Member chetwynd's Avatar
    Jul 2005
    California
    Default Sump Pump Question
    Can anyone tell me what kind of bucket and cover (if necessary) to use for a sump pump under a house in the dirt crawl space? Is a regular 5-gallon bucket with no cover OK?
    Does the drain line coming out of it have to be sloped down at the end?
    I guess I have to use PVC and not ABS, right?
    Thank you in advance!
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Default pump
    How is the water going to get into the vessel that you are planning to use for your pump ?
    Jul 2005
    Marin Co. Ca.
    go to h depot. they sell plastic sump pits and pipes. the ridgid 1 1/2 hp is a good pump. need check valve directly above water outlet
    Jul 2005
    California
    Default more...
    Planning on digging a hole, burying a bucket flush with the grade, surrounding it with some rocks, putting some holes in the bucket sides and bottom, and running it outside the house...
    Unless you have any suggestions?
    DIY Member pump's Avatar
    Oct 2005
    Indiana
    Try this link:
    http://www.zoeller.com/zcopump/prod.../crawlspace.htm
    We would recommend a check valve and you can use different pipe with this system.
    Jul 2005
    California
    Default zoeller
    yeah that setup is OK, but the catch basin is too small. That thing would be coming on every 5 minutes. Needs more capacity, more depth, bigger overall. let me know when you come up with a bigger basin.
    Feb 2005
    Talking 7 gallon bucket
    its best to install a large pit
    but if you dont want to dig that much
    you could get a 7 gallon bucket and get
    Zoeller supm pump to install in it.....
    the bucket isnt really supposed to be used, but I see
    them all the time.....
    Oct 2005
    Indiana
    Quote Originally Posted by chetwynd
    Oh we have larger basins 72"x240", you just have to let us know what size you want, but I was going on the info you gave in the post (a 5 gallon bucket), I gave you a pkg system that is pretty much the same size as what you posted! Besides, when the pump is in the bucket, it is going to reduce the area to about 3 gallons anyways.
