Results 1 to 12 of 12
Thread: PVC primer/cement not hardening
    DIY Junior Member suffer103's Avatar
    Sep 2012
    MI
    Default PVC primer/cement not hardening
    So I replaced a PVC closet flange yesterday. Today I wanted to make sure the joints were hardened before putting the toilet back on. So I was gently pushing on the excess primer/cement near the joints with a small screwdriver to make sure they were hardened.
    Its tough to tell in most spots, but where ever I got a bit of excess I could tell that I can easily push on this excess with the screwdriver. I was expecting it to be rock hard.
    I used a standard purple primer with a general purpose schedule 40/80 cement. Note that my PVC is schedule 30 (which I understand is just thin wall schedule 40).
    Am I doing something wrong? Its been 24 hours now.
    The cement, as opposed to a glue, actually is a mix of solvents and pvc disolved in it. It literally melts the pipe and fitting and has a little extra body to fill in. It doesn't resolidify until all of the solvents have evaporated. My guess is that you couldn't pull the joint apart. It should be fine. Try not to use excessive amounts.
    Sep 2012
    MI
    I gave it a decent tug and couldn't budge them.
    Great info thanks. That's a load off my mind...and hopefully one soon through my new flange.
    Sch. 30 pipe has an "actual i.d. of 3.0", which it has to have to maintain a smooth bore if used with ANY other DWV material. BUT, it has an o.d. of 3.25", which is too small to fit any sch. 40 or 80 fittings. It ONLY fits sch. 30 fittings which are not compatible with any other grade. That being the case, HOW did you attach a flange to the pipe and get any kind of proper connection.
    Sep 2012
    MI
    Originally - The schedule 30 pipe goes into a 90 elbow. They had a flange to exact fit the elbow.
    New one I installed. - I cut off the elbow, then I added two 45 elbows instead of a 90, to create a longer sweep. There was a special flange at Lowe's to fit into the 2nd elbow around the outside of the elbow. Fit perfectly.
    Edit: I'll add, most of the flange's at Lowe's would not fit (probably because they were for schedule 40 pipe).
    http://www.lowes.com/pd_104527-322-6...ontent=Default
    Nov 2010
    Maine
    My head aches
    IF you tried to dry fit things, and made your choice on that, that's where you went off the bandwagon! The fittings are an interference, tapered fit...the pipe only fits fully into the socket after you apply the cement and it melts the material.
    Mar 2011
    Houston, TX
    My head aches
    I fell off my rocker, don't feel bad.
    Sep 2009
    Seattle. WA
    ?They let you use schedule 30 pipe for house drainage piping in Michigan?
    It is usually used outside the building underground. The O.D. of a fitting is the same as the O.D. of sch. 40 pipe, which is why the flange fit over the elbow, but it was NOT, a proper connection according to the wording of the code. To use sch. 30, or S&D, pipe indoors you would either have to find sch. 30 fittings which are limited, or use 40x30 bushings into every fitting.
    Mar 2011
    Long Island, NY
    Don, quick! get back on that rocker. We don't want to be off our rocker, do we?
    quote; We don't want to be off our rocker, do we?
    Given the quality of some of the recent posted replies, I think it is too late for some people.
  1. PVC Primer and cement question
    By walkman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-17-2011, 05:38 AM
  2. SCH80 pvc cement and primer question
    By mckeand13 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2010, 07:27 AM
  3. Primer
    By sparkync in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2010, 07:13 PM
  4. Is there a PVC cement which requires no primer?
    By BimmerRacer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2009, 07:54 AM
  5. Primer Dye
    By Paul Johnston in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2008, 05:40 AM
