The cement, as opposed to a glue, actually is a mix of solvents and pvc disolved in it. It literally melts the pipe and fitting and has a little extra body to fill in. It doesn't resolidify until all of the solvents have evaporated. My guess is that you couldn't pull the joint apart. It should be fine. Try not to use excessive amounts.
, but I am a pro crastinator
