Results 1 to 6 of 6
Thread: Can all brass full port ball valves be used for hot water?
    DIY Junior Member WillieK's Avatar
    May 2011
    Houston, TX
    Default Can all brass full port ball valves be used for hot water?
    I would like to replace my water heater drain with the following valve: LDR 3/4 Inch Full Port Ball Valve.
    1. Can this valve be used for hot water purposes?
    2. Is LDR a good brand?
    3. Can all full port brass ball valves be used for hot water purposes?
    The only valves that cannot be used for hot water are PVC valves. The quality of the brass determines how good the valve is. You will know it is a bad valve after a few years and "white" spots appear on the outside of the valve.
    May 2011
    Houston, TX
    Thanks for your reply. What would the white spots signify?
    Plumber jimbo's Avatar
    Quote Originally Posted by WillieK View Post
    de-zincification of the brass
    Deterioration of the brass and water seeping through the metal.
    May 2011
    Houston, TX
    Thanks again.
  1. Electrically Actuated Full Port Brass Ball Valve 3/4"
    By OldPete in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-20-2012, 09:48 AM
  2. Three way ball valve with off position, one inch bronze, full port
    By lifespeed in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-18-2012, 10:01 AM
  3. Ball Valves - Forged Brass vs Forged Bronze
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2011, 06:21 PM
  4. propane gas; black iron & galvanized pipe; brass ball valves; dielectric couplings
    By greyhound1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2010, 06:50 AM
  5. full port valves.
    By David G in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2008, 04:43 PM
