Results 1 to 12 of 12
Thread: Question for Ba9s LED Bulb
    DIY Junior Member nicho's Avatar
    Jul 2012
    china
    Default Question for Ba9s LED Bulb
    Hi all,
    I have a LED bulb Ba9S type (130V) which has internally an array of 7 LEDS.
    All the datasheet mention is Voltage:130V AC/DC +10%, Max Current:5,9mA Colour:White clear
    In my circuit the bub is connected directly to a 110V battery and I am trying to add an external resistor to reduce the current into the bulb but before I do that, I would like to figure out the following:
    the array of 7 LEDs in a single bulb are connected in series or parallel?
    The 5.9mA refers to the current of the single LED of the whole array (if in parallel)?
    Can I assume the internal resistor is 21.47kOhm (parallel case, with 3.3V on each diode) or 18.12kOhm (series case)?
    Led Lighting. All roads lead to Rome.
    Backwards logic. The buls system is rated to operate on 130 volts. You have 110 volts which means you might get 8% less light output than design. WHY would you put a resistor in series or parallel with that to further reduce the voltage and current to the bulb.??
    Mar 2011
    Long Island, NY
    I am sitting on the edge of my chair waiting for the answer to that Jimbo. Thats a pretty small bulb package
    http://www.bulbtown.com/Miniature_Ba...s/322.htmtting
    Jul 2012
    china
    OK, thanks, just a experiment
    Jun 2007
    North Carolina
    In your opinion is this spam?
    Mar 2011
    Houston, TX
    Quote Originally Posted by jwelectric View Post
    Seems a little odd for someone that Advertizes Led Lighting.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Mar 2011
    Long Island, NY
    I don't know. It did not cause me to click on the link to whatever nicho posted. My link was gotten from a quick googling for BA9S 115 volt LED bulbs
    Mar 2011
    Houston, TX
    More on a answer to the question on operating LEDs at a higher voltage, They should be in series, and matched very close.
    Many LEDs have a built in resistor, and if they don't it would be kind of silly to use 1 per LED when 1 can be used for all of them if the LEDs are in series.
    LEDs normally short when they burn out, so the remaining ones would have a higher voltage.
    If to many of them short then the resistor may open or the fuse link will open.
    As far as I know a BA9S is the type of bulb base , not a type of bulb.
    I want a 120V battery to experiment with.
    Mar 2011
    Long Island, NY
    Yah, it is a mini bayonett basse bulb like the good ol' 47 was it?
    use 9v batteries in series or the one from your Prius (nope that is over 200 volts) or steal 10 regular car batteries
    Mar 2011
    Houston, TX
    I think the 47 and 51 were the most popular in the day.
    I would be afraid of using that base for 110 because it seems that it could arc over.
    But I think some bulbs with that base go to 220V.
    I guess times are a changing.
    Electricity must be getting safer.
    Mar 2011
    Long Island, NY
    that's b'cause of all those codes and rules make it that way. rules is rules
    quote; that's b'cause of all those codes and rules make it that way. rules is rules
    And then there are the rednecks who say, "Rules? We don't need no stinkin' rules". Or the DIYer who says, "I want to do it this way. Will someone please tell me it is okay to do it, because I will probably do it anyway".
  1. 20 Year LED Bulb
    By DonL in forum Bob & Don's Electronics Forum
    Last Post: 07-15-2012, 07:26 PM
  2. Light Bulb
    By Maverick_54 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-15-2011, 11:13 AM
  3. Why does light bulb blow?
    By Blumengarten in forum Electrical Forum discussion & Blog
    Last Post: 03-15-2009, 06:23 PM
  4. Bulb for bathroom
    By Dexter in forum Remodel Forum & Blog
    Last Post: 09-21-2008, 11:29 AM
  5. Thermostat with Remote Bulb Help
    By statjunk in forum HVAC Heating & Cooling
    Last Post: 02-11-2008, 10:21 AM
