Results 1 to 2 of 2
Thread: Strange ceiling fan
    DIY Member rayh78's Avatar
    Sep 2008
    Virginia
    Default Strange ceiling fan
    Simple enough to just replace the whole ceiling fan but is there an easier fix?
    Pull the chain for high goes in one direction. Pull again for medium slowes down and then goes in the other direction.
    Does not make any sense to me.
    Copacitor? Switch? or replace a 5 year old fan
    Any ideas?
    Mar 2011
    Long Island, NY
    Quote Originally Posted by rayh78 View Post
    Any ideas?
    It kinda sounds like the capacitor. It should be cheap enough to replace, but if the fan itself is a cheapo, then maybe better to replace it. I'm not even sure if (3) speed ceiling fans all use caps or if they use multiple pole configs that the switch changes from one spped to another. I'd go with the cap if you can find one. Do you have an old analog type ohm meter (with a dial and needle)? If you do, the cap can be checked to see if it is completely open (or shorted out) I would think if it failed and caused the motor to reverse itself, it may have lost its capactance (opened). only my .02.
  1. Gap between ceiling fan housing and ceiling
    By hfx in forum Electrical Forum discussion & Blog
    Last Post: 08-23-2012, 01:41 PM
  2. 14/3 strange usage
    By MrBillyd in forum Electrical Forum discussion & Blog
    Last Post: 04-05-2012, 05:03 AM
  3. strange
    By plumbtired2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2010, 04:51 PM
  4. strange leak
    By nm12345 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2009, 07:21 PM
  5. Installing Ceiling Fan On Vaulted Wood Ceiling
    By Verdeboy in forum Electrical Forum discussion & Blog
    Last Post: 08-17-2007, 08:10 AM
