Results 1 to 3 of 3
Thread: Need Advice: Water Heater Rush and Corrosion
    DIY Junior Member Lucy Hall's Avatar
    Sep 2012
    Texas
    Default Need Advice: Water Heater Rush and Corrosion
    Hi Everyone- I'm new to this forum and would be ever so grateful if someone could give me some advice on my water heater issue. I've lived in my home for 6 years and in the process of selling my home. The inspector came in and noticed some rust and corrosion on the connection of my water heater. The water heater is located in the attic and I live in Texas where it's hot and humid. He said that it could be normal but the Buyers want me to fix it. My question is do I need to replace my water heater or do I replace the connections or can I just get a wire brush and clean off the rust? TIA
    Normally the fix is to replace the nipple going into the tank.
    If a water heater is ten years old, then it may make more sense to replace the water heater. Spending money on a plumber to do a repair gets you part way to a new heater. Since you are moving on, that may not be an issue. In your new location, my advice would be to replace the tank, not spend it part way on a small part.
    Sep 2012
    Texas
    Thanks Terry. I will call a plumber and have him/her replace the connection.
  1. Corrosion in newly installed water heater
    By rick112 in forum Water Heater Forum, Tanks
    Last Post: 03-09-2012, 04:57 AM
  2. what metal connector to a water heater to prevent galvanic corrosion?
    By Steve603 in forum HVAC Heating & Cooling
    Last Post: 12-29-2011, 07:35 PM
  3. Water heater inlet corrosion
    By bTim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2011, 06:54 PM
  4. Corrosion Build Up On Top Of Water Heater
    By Jacen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-17-2009, 01:33 PM
  5. Water heater copper pipe corrosion
    By ralfonso in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2008, 08:00 PM
