Results 1 to 5 of 5
Thread: Shower valve with male thread
    DIY Junior Member dougeefresh's Avatar
    Sep 2012
    Chicago
    Default Shower valve with male thread
    Hello.
    I just bought a shower valve from Price Pfister and it has male threaded ends.
    Is it OK to just sweat the copper tubes on directly or should I go through female threaded ends? Any reason not to solder on the tube directly on the male end? Thanks!
    Great forum by the way!
    If you can insert the copper there, then that's the second option you have. I would solder the pipe and skip the fittings.
    Sep 2012
    Chicago
    It fits well just like any others without the threads so I will solder them on.
    That was an awesomely quick response. Thanks, Terry!
    That is the way a plumber would do it. But, it is INTO the threaded end, NOT ON it.
    Sep 2012
    Chicago
    Hi, hj,
    Yes, that's what I did and it worked like a charm.
  1. Replies: 1
    Last Post: 08-19-2010, 11:35 PM
  2. Please help! Leaking thread on shower valve
    By backwaterdogs in forum Plumbing Forum Discussion & Blog
    Last Post: 03-31-2009, 08:57 PM
  3. Shower Valve Inst - Male Threaded fittings or Unions?
    By Remodelboy in forum Shower & bathtub Forum & Blog
    Last Post: 01-24-2008, 06:59 PM
  4. Thread or sweat for new Delta shower valve install?
    By Designomatic in forum Plumbing Forum Discussion & Blog
    Last Post: 06-22-2007, 08:46 PM
  5. Male copper adapter to shower valve slight drip?
    By bathwise in forum Plumbing Forum Discussion & Blog
    Last Post: 10-29-2006, 06:03 AM
