Results 1 to 6 of 6
Thread: Uponor Aquapex Tubing and Ultraviolet Light
    DIY Junior Member WillieK's Avatar
    May 2011
    Houston, TX
    Default Uponor Aquapex Tubing and Ultraviolet Light
    Can this pex be installed in an attic close to an exterior wall where it gets indirect sunlight from an unsealed porch.
    Nov 2010
    Maine
    Just insulate it with armorflex and it will be fine.
    UV rays are "line of sight" so they do not affect pipes which are in "indirect sunlight".
    May 2011
    Houston, TX
    Thanks - good idea.
    May 2011
    Houston, TX
    I did a little research and it seems like UV rays can be reflected - even off of the concrete porch floor. However, not sure how much would actually be reflected - especially up 9 feet high?
    They are so "weak" that a single layer of latex paint will protect the pipe from them so how much effect would they have if they were reflected off a rough surface like concrete?
  1. Re-plumbing the house with Uponor Aquapex, have a couple of questions
    By DaveHo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-04-2012, 12:56 PM
  2. CPVC or Wisrbo AquaPex ????
    By Nevada in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-26-2010, 01:38 PM
  3. mixing existing copper tubing with new pex tubing
    By chickenbrown in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2009, 10:48 AM
  4. Red/Blue AquaPex (Wirsbo/Uponor) Scratch Question.
    By OldPete in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2006, 07:17 AM
  5. cpvc vs aquapex
    By sarasota,fl in forum Remodel Forum & Blog
    Last Post: 09-14-2005, 01:23 PM
