Some places require separate traps, so allow you to utilize one in this situation. If you can get by with only one with your local code, you could cut and cap the trap arm to the left with enough stub to be able to reuse it at a later date, and redo the right-hand one to cross over, connecting both, then dropping to the trap on the right. They make those cross-overs with a baffle so draining one side doesn't back up into the other (more important with a disposer, but an issue with the pump on the DW, too), and you can get them with a DW tailpiece.
Even though the term "continuous waste" was not used in your reply, I was mostly certain that you were describing the same idea as the other two responses. Thanks again!
