Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Connecting 4" Cast Iron with 3" PVC
  1. #16
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Either one, but a cast iron one will not need as much of the pipe cut out to fit it in. If you use PVC, or ABS, get a "street tee" so you only need a piece of pipe on the top end.
    Would this be a no-hub street tee? Also by "street tee" do you mean the "leg" of the tee can have a piece of PVC pipe slide right over it?
    Also, what is the problem in using a "Y"?
    Thanks again
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
  2. #17
    Nov 2010
    Maine
    Where is he going to find a street T? I'd bet that of the 6 plumbing supply houses near me, none of them carries a street T in any size. Charlotte and Mueller both say they make them though.
  3. #18
    The pvc fitting will have hubs on both ends...the street T will only have them on one end. It might make getting the whole assembly just the right length when cutting out a section easier. If you go with a CI hubless fitting, neither end will have a hub. Getting the section of pipe just right - nice square cuts with the proper gap to slide in the fitting will be tougher.
  4. #19
    Sep 2006
    cold new york
    There is a challenge to using the no-hub couplings that are available at the supply house. They have a "stop" half-way through the fitting (the rubber forms the stop). This "stop" will prevent the coupling from being slid up (or down) the pipe so that the new piece can be placed into the cut out area. In other words, I need a repair no-hub coupling. Are these made, or is there another way?
    Thanks again!
    Gore Vidal.
  5. #20
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Exclamation
    You take the rubber coupling and roll it back over itself then you
    only need a extra 1/4" or so to slide your tee/wye into place roll rubber back down and slide
    your metal band into place, ! be sure to tighten the nuts equally
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
  1. "real-world" vintage cast iron pipe cutting?
    By zimmee66 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-04-2013, 01:07 PM
  2. When connecting 4" ABS sewer line to Cast Iron, how deep is deep enough?
    By Man in forum Plumbing Forum Discussion & Blog
    Last Post: 06-08-2012, 08:16 PM
  3. Which coupling for 3" PVC to 4" Cast Iron
    By takelargebites in forum Plumbing Forum Discussion & Blog
    Last Post: 12-19-2011, 05:40 PM
  4. Looking for a quality 66" x 32" tub to replace an old cast iron job. Ideas?
    By Bosun in forum Shower & bathtub Forum & Blog
    Last Post: 04-29-2011, 12:32 PM
  5. What is best/safest way to cut cast iron drain pipe (or "undo" the fittings)?
    By diecastdawg in forum Plumbing Forum Discussion & Blog
    Last Post: 01-19-2010, 10:53 AM
