Results 1 to 15 of 20
Thread: Connecting 4" Cast Iron with 3" PVC
Hybrid View
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Connecting 4" Cast Iron with 3" PVC
    Hello,
    I have a vertical 4" Cast Iron piece that I want to connect a horizontal 3" PVC drain to. The local store has a "saddle" with a gasket on the inside and u-bolts that will wrap around the CI. The connection will be at approximately a 90 degree angle. So, the material in the PVC drain will travel horizontally at 1/4"/ft. and then drop down into the CI. Is this a common and good way to make this connection?
    Thanks,
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Sep 2009
    Seattle. WA
    It is extremely uncommon, and as far as I know illegal (contrary to plumbing codes).
    I'm not a plumber, but if I had to do this, I'd probably cut out a section, then insert a wye using no-hub connectors. Now, there may be an issue with putting pvc in the middle of the run because of the weight. If the pipes are properly braced, that shouldn't be a problem. But, you could put in a CI hubless wye, then convert to pvc, and all would be well.
    Yakima WA
    Just because a store sells it, doesn't make it legal. They still sell S traps at Ace Hardware.
    Nov 2010
    Maine
    They sell S traps because it's legal to repair or replace and existing one. Now if you want to talk about the plastic accordion tail stocks LOL
    1. It is an illegal connection. ALL plumbing codes prohibit "saddle connections" except for connections to the main sewer in the street.
    2. It is also a bad connection function wise.
    3. Cutting a 3" round hole in a 4" cast iron riser will be a very time, and tool, consuming process.
  1. "real-world" vintage cast iron pipe cutting?
    By zimmee66 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2013, 01:07 PM
  2. When connecting 4" ABS sewer line to Cast Iron, how deep is deep enough?
    By Man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2012, 08:16 PM
  3. Which coupling for 3" PVC to 4" Cast Iron
    By takelargebites in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2011, 05:40 PM
  4. Looking for a quality 66" x 32" tub to replace an old cast iron job. Ideas?
    By Bosun in forum Shower & bathtub Forum & Blog
    Last Post: 04-29-2011, 12:32 PM
  5. What is best/safest way to cut cast iron drain pipe (or "undo" the fittings)?
    By diecastdawg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2010, 10:53 AM
