Results 1 to 6 of 6
Thread: How do I extend my faucet flex supply lines?
    DIY Junior Member Scott Vroom's Avatar
    Feb 2010
    Mountain View, CA
    Default How do I extend my faucet flex supply lines?
    I miscalculated and placed my angle valves too low and now the faucet supply lines won't reach....shoulda bought the faucet first. Can I buy supply line extensions? If not I guess my choices are to remove the compression angle valves, elbow the copper up a few inches....don't wanna do this now, looking for a quick fix.
    Maybe supply extensions are not available? Maybe I just need to find a female-female coupling and add on another short supply line.
    This hack needs help
    Sep 2009
    Seattle. WA
    Why in the world would you think you need to remove the valves? Why can't you just get a longer supply line? Do you have a faucet
    with integral supply lines? If so, just get some more lines that match the valve outlet and whatever's on the end of the faucet line.
    You buy two 3/8"x3/8" compression couplings, and two 3/8"x3/8"x12" or or longer, depending on what they have, braided stainless steel hoses.
    Feb 2010
    Mountain View, CA
    Would you mind posting a picture of the 3/8" x 3/8" compression couplings you refer to? The end of the braided hose comming off the faucet has a 3/8" female fitting with a rubber washer....doesn't sound like a compressing fitting to me. Thanks.
    Sep 2009
    Seattle. WA
    The threads of the nut at the end of the faucet supply line are meant to attach to a 3/8" male compression fitting, as is found on the vast majority of
    supply valve outlets used today in the U.S. The fitting HJ mentioned is just a chunk of brass with a male 3/8" fitting at each end.
    Feb 2010
    Mountain View, CA
    Understood.....already picked up the piece parts at the local hardware. Easy fix.....after you've done it once
    Thanks for the help folks....
    Quote Originally Posted by kreemoweet View Post
  1. Ok to connect two SS flex supply lines?
    By moose186 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-19-2010, 06:58 AM
  2. clawfoot tub water supply - flex?
    By ChrisRice in forum Shower & bathtub Forum & Blog
    Last Post: 09-26-2010, 08:47 AM
  3. Kitchen faucet - bending copper supply tubes
    By Optiker in forum Plumbing Forum Discussion & Blog
    Last Post: 07-30-2008, 05:06 AM
  4. Saddle Valve into flex water supply line?
    By kine97 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-30-2007, 09:02 PM
  5. Supply extensions
    By bobsmith in forum Plumbing Forum Discussion & Blog
    Last Post: 01-24-2006, 05:20 PM
