Thread: IPv6
    Plumber jimbo's Avatar
    Default IPv6
    Can someone bottom-line this?? I get the issue...ran out of IP addresses, so shifting to 128 bit vs 32 bit. ATT ( dsl ) sent me an email saying that at SOME point, I have to replace my dsl modem. Will this be a gradual thing?? This week? This year???
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    If they are upgrading there system, it means faster DSL and the old router can not keep up.
    Check with your provider.
    DIY Junior Member aquadood's Avatar
    Jul 2012
    Atlantis, TX
    The old Version 4 had a a limit of about 4000000000 addresses and as you see everyone uses a computer and they started running out of possible addresses to use so they came out with version 6 which can handle Approximately 300000000000000000000000000000000000000 different addresses to figure in growth for a good long while
    It may be a few years till there is 100% version 6 switch over. When you get a new modem you will be using version 6 as simple as that.
    They most likely want to get people to switch over to because its easier on them to give out addresses from the bigger v6 space.
    Maybe you can get a complimentary modem upgrade if your leasing it, that may also boost your speeds a bit depending on how old your current one is.
    Mar 2011
    Houston, TX
    Quote Originally Posted by aquadood View Post
    You can blame all the iPhone users for running out if IP addresses.
    Everything has a IP address now a days.
    That includes the smart meters and the kitchen sink.
