Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: UPC Code question about water service sizing
  1. #31
    If the city approved the plumbing diagram and the pipe sizes on it, then even with their caveat they could have some, or a lot of, liability if the plumber installed it that way.
  2. #32
    Mar 2011
    Houston, TX
    It is like blaming the pipe layer for getting a bad lay.
    The inspector is to blame , not the plumper, even if he had his head up his ass when he installed it.
    It is to late now, and the homeowner will lose. You can not fight city hall, and they must have already approved it.
    That is how I see it.
  3. #33
    Not only should the sprinkler system not run through the regulator, it must be separated from the domestic supply with an approved back flow prevention device which is to be certified annually. These are federally required, but not all cities pay attention to the law. Also, with a pressure regulator, even though it is not needed to reduce you pressure, you need a thermal expansion tank. Get rid of the regulator and no need for the expansion tank.
  4. #34
    DIY Junior Member mike mann's Avatar
    Sep 2012
    utah
    other than the plumber doing it his way i don't think there ever was a plan. electrical shows on the plans that i have seen but no plumbing other than the location of the drains. could the lack of water have anything with the toilets plugging up? more in 1 1/2 years than our previous house of 25 years. thanks again-mike mann
  5. #35
    Mar 2011
    Houston, TX
    Quote Originally Posted by mike mann View Post
    As long as the toilets fill then they should flush.
    I would say No.
  6. #36
    The quality of the toilet and proper drain pipe installation (well, what you put down it can make a difference too, at least to a point) are what determine how well a toilet flushes. They are NOT all created equal, and some of the old standbys do not always produce reliable, quality products. As long as the water level in the tank is proper, the toilet's not plugged, and the flapper opens the proper amount of time to release the design amount of water, that's as good as the toilet gets. Some are a lot better than others. Water pressure has nothing to do with it (unless you're using a pressure assist or Flowmaster type flushing system). You need enough pressure to operate the fill valve, but other than that, volume in and of itself is not a factor...it may just take longer to refill.
  1. Sizing Question for very hard water and one person
    By Mike16W in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2011, 02:35 PM
  2. Water heater service disconnect question
    By turnsouth in forum Electrical Forum discussion & Blog
    Last Post: 08-16-2010, 12:26 PM
  3. How water pipe sizing question
    By smallshop in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-30-2009, 12:15 PM
  4. Hot Water heater sizing question
    By ron in sc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2008, 07:08 PM
  5. Commercial Water Service Pricing Question...
    By BSA Construction LLC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2007, 05:21 PM
