Results 1 to 3 of 3
Thread: Simple solution for new kitchen island... ?
    DIY Junior Member Oafed's Avatar
    Sep 2012
    Arizona
    Default Simple solution for new kitchen island... ?
    Adding a small island to the kitchen. Here are my current plans for running the electric through the concrete slab (for 2 outlets on the island). The slab isn't post tension or anything. Please provide your thoughts? I will be doing this in the next week or so.
    -Cut a 2" deep V channel in the slab (about 4 feet long) with a circular saw
    -Put in a 1/2" rigid steel conduit with elbows at the ends to bring it out
    -Paint on some concrete bond coating / glue and fill V channel with concrete patching mortar
    This will allow about ~1" cover over the rigid steel conduit. I know PVC has a 2" cover requirement, but I do not believe this is true for rigid steel conduit? I just don't want to cut a huge channel all the way through the slab just to run 4 feet of conduit to the island. I also don't want to mess with jets.
    Will my idea work?
    DIY Senior Member TJanak's Avatar
    Sep 2009
    South TX
    That's what did, except I probably only had 1/2" of cover.
    And if you are at all concerned about dust have a helper use a low pressure water hose and a shop vac at the circular saw. The water stays off of the saw motor and just don't stand in it either. Worked great for me.
    Travis
    When I need a precise measurement of something I often use the highly technical method of eyeballing it.
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Run a isolated circuit if you can.
    Don't know how you plan to use the island, but presume the counter is fill, and someone walks the mixer over to the island.
    I've got 4 dedicated outlets and sometimes I wish I had more....
  1. Running wire for island receptacle in kitchen remodel
    By TJanak in forum Electrical Forum discussion & Blog
    Last Post: 12-27-2011, 11:01 AM
  2. moving an island
    By Mr. Fixit in forum Electrical Forum discussion & Blog
    Last Post: 07-01-2011, 11:03 AM
  3. Kitchen Island rough-in
    By johnvb in forum Plumbing Forum Discussion & Blog
    Last Post: 12-30-2010, 03:20 PM
  4. Kitchen Island Vent
    By william505 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-03-2005, 06:39 PM
  5. "Simple" kitchen drain question
    By eddie813 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-29-2004, 08:31 PM
