If it is the rough-in guide, you can remove it, but it isn't essential. On thinwall installations, some valves use that to sandwich the thin wall of the enclosure with the trim to help hold things in place. Normally (with a tiled wall), though, you'd anchor the valve itself and remove it after the wall rough-in is done.
