Results 1 to 5 of 5
Thread: Wiring 2 Honeywell zone valves
    DIY Junior Member pagregg's Avatar
    Sep 2012
    PA
    Default Wiring 2 Honeywell zone valves
    I have 2 zones each with a Honeywell zone valve. (the valves have "end switch on top and TH-TR...TH...TR on bottom) I need to know how to connect the second valve. The first valve is connected to the transformer, thermostat and aquastat and works correctly. On the second I connected to the first valve by running the wire from fist valve "end switch" to the second valve TH-TR & TR with the second thermostat connected to the TH-TR & TH. It doesn't work??? Am I correct in thinking that I don't run the second valve to the aquastat as it is going through valve 1?
    Thanks for any help!
    Nov 2010
    Maine
    Sep 2012
    PA
    Yep same as what I got when I purchased the valve, still not sure what is wrong.
    You are confusing "circulator or another valve" with a zone valve. That "other valve" would be the burner's gas valve or whatever turns the system on. Each zone valve needs a supply line from the transformer, and a control wire from the thermostat. This allows each zone valve to operate independently, but BOTH have to be wired in parallel from the "end switch" to the boiler's "control circuit", gas valve or circulator, depending on whether it is a constant temperature or "on demand" system.
    Sep 2012
    PA
    Nope not confusing it at all! I have 2 two zone valves that i need to connect...wow
  1. Honeywell Zone System Damper Question
    By GrantK in forum HVAC Heating & Cooling
    Last Post: 11-20-2008, 06:34 PM
  2. Honeywell V8043F1093 zone valve
    By bjesik in forum HVAC Heating & Cooling
    Last Post: 03-28-2008, 06:03 PM
  3. Honeywell Zone Valve Replacement
    By devans175 in forum HVAC Heating & Cooling
    Last Post: 12-18-2007, 12:23 PM
  4. # of Honeywell Zone valve
    By rockycmt in forum HVAC Heating & Cooling
    Last Post: 12-06-2007, 09:53 AM
  5. Honeywell motorized valves
    By r247yan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2007, 06:20 AM
