Results 1 to 4 of 4
Thread: Culligan Ironcleer System failure
    DIY Junior Member Eco1111's Avatar
    Sep 2012
    Clifford, Ontario
    Default Culligan Ironcleer System failure
    My Ironcleer system recently died - apparently it the compressor died. I have only had the system for 5 years, so I have a couple questions:
    1) How is the stress on the system related to the work that the compressor does? ie. is there additional 'work' that the compressor does per cycle if the iron in the water is higher?
    2) What is the average life span of a compressor?
    3) Given that I paid $3500 for this unit, that works out to $700/year to remove iron from my water. Is this a reasonable cost?
    Thanks and Regards,
    Nov 2010
    Maine
    Obviously the more iron and the more water you use, the more the compressor runs but you should get more than 5 years out of it. Unfortunately, I suspect it's out of warranty and to make things worse, you can probably only get another one from Culligan but maybe you can go with some other makers pump.
    Jan 2012
    California
    Cost is relative. You may look to replace it with a different design in the future. There are several reputable companies that sell Iron removal units. I prefer the ultra simple Pyrolox type of units that simply backwash every couple of days. Air injection can be added for a minimal cost. Other common and simple designs are the chlorine injection/contact tank/ backwash GAC systems. Chlorine can be injected by a pellet design, water pump, or electric pump. All three are good and each has their advantages and disadvantages. Iron removal can be tricky, do you have a recent water test so we can make a better recommendation?
    Dec 2009
    Alaska
    Is the compressor leaking water or not putting out air?
  1. Culligan Water Softener system - virtually zero water flow
    By Qckslvr in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-07-2011, 09:26 PM
  2. Rebedding a Culligan Carbon Filter / General Water Treatment System Questions
    By scrupul0us in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-11-2011, 08:23 AM
  3. Need help with Culligan filter system part
    By DC76 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2008, 12:30 PM
  4. Septic system failure
    By lardlad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-16-2008, 11:14 AM
  5. flushing failure
    By jaybird in forum Toilet Forum discussions
    Last Post: 05-17-2005, 05:27 PM
