Results 1 to 4 of 4
Thread: Questions About Brass vs PVC Tub Drain Assembly To ABS Trap
    DIY Member DavidSeon's Avatar
    Jul 2012
    MS Gulf Coast
    Default Questions About Brass vs PVC Tub Drain Assembly To ABS Trap
    I have a couple of novice questions about tub drains. Because of the tub "the boss" picked out, I think I need to replace the existing drain (Brass to ABS trap):
    Name:  Back Bath 2012-09-08 Tub Drain 2.jpg
    with a Kohler slot-type overflow drain:
    Name:  Back Bath  Kohler Bath Drain - Brass.jpg
    I'm a little confused about the size of the Brass tailpiece vs the ABS trap fitting it slides into. The Inside Diameter of the ABS fitting and the Outside Diameter of the existing tailpiece are both right at 1 1/2", with the tailpiece OD maybe a couple of thousandths smaller according to my caliper (obviously, or it wouldn't fit). Is Brass sizing one of the cases where nominal size refers to O.D. rather than I.D., or is this some kind of special tailpipe made to fit into 1 1/2 ABS? In other words, if I order the Kohler drain (which calls out the tailpiece as 1 1/2 O.D.), should I expect it to be the same slip fit into the ABS, using the same type washer and nut as the existing?
    Also, the Kohler drain is available in PVC as well as Brass, for about $50 less:
    Name:  Back Bath  Kohler Bath Drain - PVC.jpg
    Obviously, 1 1/2" PVC wouldn't fit into the ABS trap because the O.D. would be too large. Is there some kind of transition from PVC to ABS I could use to save a few bucks, or are there other advantages to sticking with the Brass?
    Thanks for your patience and help.
    Dave
    Old Retired Computer Programmer
    Obsolete and loving it
    Tubular piping for drains, whether brass or pvc, should be interchangable..IOW, they should be the same OD. The same compression fittings should work.
    Sep 2009
    Seattle. WA
    If the PVC drain is specified as Schedule 40 (normal ABS/PVC/Galv Drain/Waste/Vent piping size), then it won't fit. Schedule 40 "glued" tub drains are used where there is no
    access to the drain. Brass tubular size drains (no matter what they're made of) with slip-joint fittings require access. The photo you posted looks like it has a Schedule
    40 santee meant to be glued to Schedule 40 PVC trap/piping below.
    Jul 2012
    MS Gulf Coast
    Ok, thanks for the replies. Ordered the brass.
    Dave
  1. Tub Drain - Trap and fitting questions
    By techinstructor in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-02-2011, 07:25 AM
  2. Can I combine brass/chrome and plastic p-trap segments?
    By npurdy506 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-19-2010, 10:32 AM
  3. Brass P-Trap to Cast Iron DWV
    By jlsddmar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2010, 01:36 PM
  4. leaking brass transition to abs trap
    By mj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2010, 07:54 AM
  5. Chrome plated brass p-trap to 2" PVC
    By jaglass in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-03-2007, 12:33 PM
