Results 1 to 3 of 3
Thread: Sand Sucker Stuck how to get out?
Hybrid View
    DIY Junior Member Tomnet's Avatar
    Sep 2012
    Michigan
    Default Sand Sucker Stuck how to get out?
    Driving a 3" pipe, plan is to put a 2" point and pipe down once in good water. Sand sucking the well, and the sand sucker is stuck? We are in very fine sand/water mix. I believe it is just stuck in the mud, but don't want to pull on the rope to hard and break it! Any ideas on how to free it?
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    Not enough information! But if it's a sand bailer I suspect it's pulled it's self into the sand and become stuck! If this is the case you only have the option of pulling it back carefully.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    DIY Member bcpumpguy's Avatar
    Jul 2012
    Langley BC
    thats pretty cryptic, however it sounds like you are using something to actually pull the sand out of the well but its stuck, reverse flow, shoot water down it. should loosen it up.
    ps: is a sand sucker kind of like a wire or paper stretcher?
  1. Quikcrete Sand/Topping Mix--should I add more sand?
    By jolycu in forum Shower & bathtub Forum & Blog
    Last Post: 03-10-2012, 07:56 AM
  2. floor sucker pump for use in fish room
    By BHHOWARD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-01-2010, 08:08 PM
  3. Sand will not end
    By Big Archery Nut in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-28-2009, 10:02 AM
  4. New Well: Sand in the tub
    By mickeygil1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-12-2008, 06:01 AM
  5. 4 inch sand sucker
    By gsecord in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-22-2008, 08:42 AM
