Results 1 to 15 of 37
Thread: water spot size?
Hybrid View
    DIY Member charles2's Avatar
    Apr 2008
    Georgia
    Question water spot size?
    Is there a list somewhere of water spot sizes? Looking for a good performing, reliable, elongated gravity flush ADA model with the deepest and widest water spot.
    DIY Junior Member GeorgeCT's Avatar
    Apr 2011
    I know Toto lists water spot (Toto lists it as "Water Surface") on each toilet.
    Form the Toto web site ( http://www.totousa.com/ ) Select a toilet, click on the "Downloads & Resources" tab, click on "Spec Sheet", click on models listed, located on the second page is the Water Surface size.
    I don't know of an easy way to find water spot size in a more efficient manner.
    Apr 2012
    New York, NY
    I will at least tell you about some Totos you should consider. All the Totos I list meet your criteria for ADA (or "Universal") height, and are: (a) Reliable; (b)gravity toilets with (c) a GREAT flush.
    The original Drake: CST744SL: ADA Height, 1.6gpf, Water Spot 10 3/8" x 8 1/4"
    The Eco Drake: CST744EL: ADA Height, 1.28 gpf, Water Spot 10 3/8" x 8 1/4"
    Drake II: CST454CEFG: Universal Height, 1.28 gpf, Water Spot 7 1/8" x 9 1/8"
    Drake II 1G: CST454CUFG: Universal Height, 1.0 gpf, Water Spot Size not yet available (different-looking tank and trip lever from the standard Drake II)
    Ultramax II: MS604114CEFG: One-piece toilet, Universal Height, 1.28 gpf, Water Spot 7 1/8" x 9 1/8"
    Original Ultramax: MS854114SL: One-piece toilet, ADA Height, 1.6 gpf, Water Spot 10 5/16 x 8 1/4
    Eco Original Utramax: MS854114EL: One-piece toilet, ADA Height, 1.28 gpf, Water Spot 10 1/4 x 8 1/4
    Hope this helps.
    Apr 2008
    Georgia
    Thanks. Is Toto the only mfr that lists water spots?
    Apr 2012
    New York, NY
    Quote Originally Posted by charles2 View Post
    I'm sure not. But it's the best one, and the one most often recommended on here. After I just did a bunch of work for you, at least read the toilet reviews in the green box above.
    Apr 2008
    Georgia
    Thanks and I apologize if I seemed ungrateful. I've heard lots of good things about Toto over the years (I'm a remodeler). Problem is no Toto dealers in my area, so I'm left with American Standard and Kohler. Kohler's Highline Classic 14799-0 has a 11-3/8 x 8 water spot, which seems to be at least as good as any you listed. I'm also interested in American Standard's 710FA.101.020, but can't find any specs on their website.
    Apr 2008
    Georgia
    Quote Originally Posted by wjcandee View Post
    It used to be that Toto's CST704L, Kiki CST703 and CST713 were highly regarded, but I don't see these on Terry's list. What happened to them? And does Toto still use universal replacement parts?
  1. Is water spot size affected by flange diameter?
    By chrisexv6 in forum Toilet Forum discussions
    Last Post: 12-28-2008, 02:11 PM
  2. Emulsified Water-No Spot Car Wash
    By Mike50 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-23-2008, 04:36 PM
  3. TOTO Dartmouth water spot = TOTO Drake water spot?
    By Sepp in forum Toilet Forum discussions
    Last Post: 04-04-2007, 10:39 AM
  4. Water heater-wet spot
    Last Post: 12-30-2006, 05:06 PM
  5. Kohler Cimarron normal water spot size
    By nc-terp in forum Toilet Forum discussions
    Last Post: 10-21-2005, 10:22 AM
