Results 1 to 8 of 8
Thread: Core Drilling and Floor Drain Question
    DIY Junior Member Brian B's Avatar
    Aug 2011
    SC
    Default Core Drilling and Floor Drain Question
    I have been tasked many times over the years with installing additional floor drains where core drilling is involved. I have done this many different ways with mixed success. I am not a plumber, i am a Facilities Manager with 20 years experience and have capable staff and decent equipment, we do a lot of plumbing. Here is my question:
    What is the proper way to install a floor drain in a commercial setting where the floor has to be cored? Do you core a 4" hole followed by a 6" down a couple inches, chip out the concrete and set the drain? What is the right material to set it in? What is the best drain to use?
    Any help is greatly appreciated!
    Brian
    Coring twice is nice.
    I use a cast drain in that situation with an adjustable top.
    I've let the flooring installers worry about the the back fill on the drain. Maybe someone here does flooring and can answer that.
    DIY Member JoshRountree's Avatar
    Nov 2009
    Fleetwood, NC
    Not sure if this will help or not, but seemed pretty good to me. Not sure on the core drilling part though.
    http://www.*******************/adjust...s-install.html
    Drilling a lorge hole for the drain's flange, and a smaller one for the drain pipe is the only way to provide support for it. But the larger hole is usually drilled first, then the smaller one. This gives better control of the water into the lower level.
    Cool Core drilling for floor drains
    Well, for someone who doesn't know about core drilling you hit it right on the head.
    For recessed floor drains that is exactly how you would proceed. We often have core drilled holes of this nature to set something back into the concrete like it was made to go there.
    This also works great for grates and floor lighting.
    But first drill the large hole so you have material (the concrete floor) to work with as far as getting the recess as flat as you can, this is where the chipping hammer comes in. Once you got it the depth you want then drill the smaller hole for the piping.
    We are professional core drillers in North Carolina
    Charlotte core drill
    http://www.charlottenccoredrilling.info
    Jun 2009
    Canada
    I find it interesting that random professionals come out of the wood work, create an account, and advertise for themselves like this...
    DIY Junior Member Subsurface Imaging, Inc.'s Avatar
    Sep 2012
    Southern California
    I couldn't agree more...
    (I'm actually here reading some articles and came across this thread. Thought I would register and hang out for awhile)
    Like "how"?
  1. garage floor drain question
    By alaskapanic in forum Drain Cleaning
    Last Post: 01-09-2012, 04:07 AM
  2. Well drilling question
    By hosky in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-22-2009, 09:39 AM
  3. Question on planning for inspection and floor drain
    By camerono in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2006, 10:25 AM
  4. drilling floor joists...
    By coach606 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2006, 07:35 PM
  5. Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
    By paule123 in forum Shower & bathtub Forum & Blog
    Last Post: 06-12-2005, 10:15 AM
