Results 1 to 5 of 5
Thread: grundfos cu301 for irrigation--VFD? CSV? Homeowner at wit's end part 2
    Moderator valveman's Avatar
    Mar 2006
    Default grundfos cu301 for irrigation--VFD? CSV? Homeowner at wit's end part 2
    Continuation from;
    at this link:
    http://www.terrylove.com/forums/show...r-at-wit-s-end
    DIY Junior Member Mfoster's Avatar
    Sep 2012
    North Caroliina
    4 months after installation of Grundfos SQE-22 with CU301 controller box, no water. Luckily I have another well and have connections as such so that all I had to do was switch a couple of valves and now I have water again from other well.
    I used Grundfos' troubleshooting guide and looks like I probably have a defective Pressure sensor transducer. I would have never installed such a system but went with this system on recommendation of well driller/pump installer. Now that I have
    "educated" myself a little bit about pumps was wonder what I should do as far as putting a CSV in along with a pressure switch and then not worry about this system breaking down again. My question is with this pump can I use it without the
    CU301 controller?
    Mar 2006
    Hello Mfoster. Thanks for the post. I am sorry this thread got so confusing in Part 1 that you missed the most important part, which is how to fix your immediate problem. This subject being so confusing was the second most important thing I was trying to convey. Looks like I got the second part right, but not the first. Here is the quote from Part 1 that you need.
    “That pump will work without the CU301 controller. Just remove the CU301 and install a regular 40/60 pressure switch. The pump will just cycle on and off quickly using the little pressure tank.
    The regular pressure switch will get it back to running and get your water flowing. Then you soon need to add either a large pressure tank to slow down the cycling on and off, or you can install a CSV with the small tank to eliminate cycling and deliver constant pressure.”
    Sep 2012
    North Caroliina
    Valveman,
    Thanks for the response. I have actually already fixed the problem. As it turns out it was not the CU301 controller, but the Pressure sensor transducer which was faulty. It was still under warranty, so I did not have to put in a new controller. It was just a Pain to figure out what was wrong and then correct the problem. I didn't buy this system to work on constantly. Reminds me of my old Volvo, was great when it ran, but it was just a pain to keep it running. As you get older you get tired of working on things that should work in the first place. If anything happens again to this system, I will get a CSV and pressure switch and install it and then hopefully forget it.
    Dec 2009
    northfork, california
    Nothing seems to be a perfect solution. I recently broke into a obscure pipe feeding a vineyard that had been shut off at the pump house for 2 years. Yet it was flowing about 2GPM, probably for a few years. Bad english gate valve of supposed good quality.
    If I had a CSV I suppose the pump would have run forever, and cost a fortune, [or] but then perhaps it would have made me look for the issue.
  1. grundfos cu301 for irrigation--VFD? CSV? Homeowner at wit's end
    By gardenerDC in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-06-2012, 11:52 AM
  2. Grundfos SQE10-5 and CU301
    By rossy65 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-01-2009, 03:59 PM
  3. The Dreaded Grundfos CU301
    By twobeemers in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-27-2008, 12:32 PM
  4. Grundfos SQE Well with CU301 Control Box
    By rob brunkow in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-11-2008, 02:37 PM
  5. Grundfos CU301 is dead - switch to CSV?
    By flynmoose in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-06-2008, 07:51 AM
