Results 1 to 6 of 6
Thread: Heavy condensation on my pressure tank
    DIY Member dwassner's Avatar
    Jan 2012
    NEW YORK
    Default Heavy condensation on my pressure tank
    I have a 308ft well that was dug within the past 6 months and our pressure tank is sweating pretty bad. I understand that the cold water is bringing the temp. of the bottom area of the tank below the dew point temperature. It is a wellmate fiberglass tank that is roughly 4 ft tall. I also just installed and am bypassing a softener and assume that once in use, it will have the same issues. The pressure tank sits on a base so i cannot wrap the entire area with insulation. I would like to solve this so a mold issue does not start. Is there a jacket you can zip around the tank? Or something you could apply to the surface of the tank? thanks
    Feb 2011
    NW Ontario, Canada
    I also have a WellMate composite tank and had no problem to wrap it in insulation. I also wrapped both the iron filter and softener. I used the foil and bubblewrap insulation. You can make cuts in it to form it to the curves and then use foil duct tape or vapor barrier Tuck tape.
    I often wondered why someone doesn't come out with a wetsuit like material with a zipper.
    BTW, I only wrapped the WellMate up to the high water mark. It doesn't sweat on the top third.
    Jan 2012
    NEW YORK
    OK, I will try that. Did you wrap between the base and the tank? Was it only one layer of insulation? I didn't realize there was a high water mark...
    Feb 2011
    NW Ontario, Canada
    I wrapped the bottom curve down to the plastic base but nothing under the base. I used 2 layers. As for the high water mark, my tank doesn't have a bladder. A bladder tank would be different. If it sweats all the way to the top then cover it to the top.
    DIY Member bcpumpguy's Avatar
    Jul 2012
    Langley BC
    Funny you say that, there is a company on your side of our beautifull country that does, can't quite think of the name right now but once i get to work tommorow i'll let you know. But that is exactly what it is, wetsuit material with a zipper. They might only have it for filter tanks though.
    Jul 2012
    Langley BC
    excalibur water systems
    Telephone: 705.733.8900
    1.877.733.8999
    Fax: 705.733.8904
    E-mail: info@excaliburwater.com
    Address: Barrie Ontario L4N 8W8
    Canada
  1. Preventing tank condensation on well water
    By minute_basset in forum Toilet Forum discussions
    Last Post: 01-25-2012, 09:47 AM
  2. toilet tank condensation
    By steve1940 in forum Toilet Forum discussions
    Last Post: 09-27-2010, 10:15 AM
  3. Condensation on toilet tank
    By nitu in forum Toilet Forum discussions
    Last Post: 05-02-2008, 04:46 PM
  4. Pressure Tank-condensation
    By jjmjones in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-01-2007, 05:12 AM
  5. Won't build pressure during / after heavy rain
    By Hatchgravel in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2007, 06:29 AM
