Results 1 to 5 of 5
Thread: Moen Tub/Shower piping size & cartridge replacement...
    DIY Junior Member Why did I try this?'s Avatar
    Aug 2012
    Wisconsin
    Default Moen Tub/Shower piping size & cartridge replacement...
    Hi,
    My original tub/shower piping is 1/2" i.d. but then goes down to these narrow elbows into a Moen 1016p valve body. Is it standard to have the pipe connect in the valve body instead of o.d. of the valve body?
    Thank you
    A picture may be nice. Are you talking about street 90 bends into a Posi-Temp valve?
    Many shower valves have male threads to accept a female threaded connector from the supply line. But, the inside of that valve is often bored out to accept the pipe in as if it was a coupling (i.e., it is the proper sized socket for accepting the supply pipe to be soldered in). Without seeing what you have, it probably is okay, but we'd need to see it to be sure.
    Aug 2012
    Wisconsin
    Here it is Name:  Valve.jpg
    My guess is that it is 3/8" i.d. The outside appears to be 1/2". The actual bent part, not the elbow openings.
    The connection IS 1/2", but then they connect 1/2" PEX to it which DOES decrease the i.D. to about 3/8".
  1. Moen 1225 Cartridge Replacement - Tips Please
    By DIYERFROMVA in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2010, 06:31 PM
  2. Moen cartridge was stuck, replacement leaks
    By TimboFish in forum Shower & bathtub Forum & Blog
    Last Post: 11-16-2009, 11:46 AM
  3. MOEN Shower Faucet Cartridge Replacement Issues
    By caldwelltim in forum Shower & bathtub Forum & Blog
    Last Post: 03-30-2008, 01:06 PM
  4. Moen 87130 Chalet Cartridge Replacement
    By snappee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2008, 06:12 AM
  5. Moen Chateau cartridge replacement aftermath
    By loquin in forum Shower & bathtub Forum & Blog
    Last Post: 12-07-2007, 11:15 AM
