Results 1 to 5 of 5
Thread: Fill Valve Spraying Tank Lid
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Fill Valve Spraying Tank Lid
    The Fill Valve is spraying out of it's top. It hits the tank lid and drips out onto the floor. Is there an adjustment that can be made to prevent this?
    Thanks in Advance,
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Apr 2012
    New York, NY
    Yes. But give us more info so we can help.
    Do you know the make and model of the toilet? The type of fill valve? Can you post a photo?
    Some fill valves will drip downward during refill. Spraying up and onto the tank lid isn't going to work well for you though. Are you sure it isn't an unused port for the tube that refills the bowl through the overflow tube?
    Look closely at the tube going to the overflow, and make sure it is fully inserted onto the nub of the fill valve, and isn't split or cracked.
    Sep 2006
    cold new york
    I won't be able to provide a photo. The problem exists at my mothers house where I was visiting this past weekend (250 miles away).
    I did check the flex tube from the fill valve to the overflow tube and it is not spraying. The spraying is coming from around the top of the fill valve. The fill valve looks like a modern fill valve, but it does have the floating ball w/rod.
    Thanks in Advance,
    Bill
    Gore Vidal.
  1. Water use - hissing G-Max Korky 528 fill valve - Quiet Fill
    By urdrwho in forum Toilet Forum discussions
    Last Post: 09-23-2012, 04:15 PM
  2. Fill valve in locked position won't fill
    By LarryShort in forum Toilet Forum discussions
    Last Post: 07-13-2012, 10:37 PM
  3. fv75 fill pro delta toilet fill valve operation
    By SuperSewist in forum Toilet Forum discussions
    Last Post: 11-07-2010, 08:01 AM
  4. Water spraying or misting from well tank
    By hd82 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-08-2009, 07:34 AM
  5. Water spraying or misting from well tank
    Last Post: 05-28-2009, 06:34 AM
