Thread: Change ShowerHead at Attachment
    DIY Junior Member CZChang's Avatar
    Sep 2012
    New York
    Default Change ShowerHead at Attachment
    Hi - I'm looking to replace this showerhead, but only at the female/male attachment. I'm quite new to this so I'm not sure what type of specifications I should be looking at to make sure the new one I buy will successfully attach at the indicated point. How do I know when buying a new showerhead that it will be able to join at that point?
    Doing some research, my current one seems to be either
    1) http://www.homedepot.com/h_d1/N-25ec...ct_description
    OR
    2) http://www.homedepot.com/h_d1/N-25ec...1#.UEfdmY2PVvE
    Sep 2009
    Seattle. WA
    The showerhead actually begins upstream from the joint you display, with the first nut that screws onto the pipe emerging from the wall. It is probably
    a standard 1/2" Female Pipe Thread nut, which you will also find on just about any replacement showerhead. If for some strange reason you actually want
    to replace only the parts you have removed, you will probably have to find an identical showerhead and dismantle it to get the items you need.
    Plumber jimbo's Avatar
    Not going to happen......EVER. brands and models NEVER mix and match at the fittings.
    The only thing that will fit where you want to mount it is another shower head EXACTLY like the one you have. Take the other piece off the shower arm and you can use any shower head you want to.
  1. Toto Upton Showerhead vs 10" Square Rain Showerhead
    By gvladybug in forum Shower & bathtub Forum & Blog
    Last Post: 08-27-2012, 11:23 AM
  2. Wire Size / Fixture Attachment
    By OscarG in forum Electrical Forum discussion & Blog
    Last Post: 08-21-2007, 01:48 PM
  3. Help posting attachment
    By alternety in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2006, 09:15 PM
  4. How do I dissconnect my sink spray attachment
    By noclue2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-22-2005, 06:37 AM
  5. Old Delta Shower Attachment
    By Jacqui in forum Shower & bathtub Forum & Blog
    Last Post: 04-22-2005, 05:36 AM
