Results 1 to 13 of 13
Thread: Rough in
Hybrid View
    DIY Junior Member afrye707's Avatar
    Sep 2012
    idaho
    Default Rough in
    I am doing the rough in plumbing in my barn for a bathroom (vanity, toilet, shower) my questions are how close should I bring my 4" main waste line to my first 3" wye or does it not matter? Can I have a elongated 90 in my main 3" line, I need to go 4" to a 4" 45 then my 3" needs a 3" 90 all in slab or should I avoid 90's until in put my pipes up my wall? I am currently working on a layout in my head that I will poast later.
    It doesn't matter, and you use the "correct" fittings you need to do the job.
    Sep 2012
    idaho
    What would be a correct fittings? when drawing my layout I feel like I should have as little to no 90's and 45's in any of my 3" pipe or 4" main waste line if possible.
    Nov 2010
    Maine
    You have whatever you need to make the system work.
    If you want to fix a faucet, this is where to come. If you want to do an entire DWV system, that is a different matter. I have NEVER seen a DIYer install a proper system by just asking for a description. In fact some of the worst abortions I have seen have been when they worked from a correct drawing, but decided to interpret it the easy way.
    Sep 2012
    idaho
    I am not a DIYer. I run a HVAC company that specializes in radiant flooring or hydronic heat. I just wanted to ask those two questions here in my drawing I don't think a DIYer would be able to draw this. I have two options send the pipe through my footing with no joints or extend my pipe down making me install a swiping 90 and a 45 but drilling through only a couple inches of cement. All I am asking is what would you do? Name:  Pipe diag.jpg
    Sep 2012
    idaho
    This drawing is for the downstairs upstairs I will have a 2nd bathroom with the same set-up plus a kitchen with dishwasher and sink, and a stub out for a wash machine. Would it be ok to wet vent everything but the shower? Or just wet vent it all like you said?
    Nov 2010
    Maine
    that depends on your trap to vent distances. You can only wet vent a bath group though (no washers or kitchen sinks etc) and you can only wet vent on one branch interval
  1. Replies: 8
    Last Post: 03-19-2012, 06:47 PM
  2. tub rough in
    By jetlag in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2009, 01:19 PM
  3. rough in
    By damorej in forum Toilet Forum discussions
    Last Post: 02-16-2005, 10:36 AM
  4. Need help with rough-in
    By dircom in forum Remodel Forum & Blog
    Last Post: 02-12-2005, 06:03 AM
  5. 13 1/2 rough in
    By jack in forum Toilet Forum discussions
    Last Post: 02-07-2005, 04:02 PM
